Keeping adhesives from drying out after opening.
Hal
Vermont
Buy the absolute smallest container you can, even if it costs more. You have a better chance of using it up before it goes bad.
PugetDude
Superstition Mountains, AZ
I hear ya, @PugetDude. But for a product like POR-15, unless one is gonna use it up fairly quickly, the small cans are the cheaper route despite their higher unit cost.
I understand unit cost, but paying more for a pint than a quart ( or 125ml vs 250ml for the rest of the world) makes absolutely no sense to me. At least with the larger container you aren't going to run out and you'll stand a chance of using it later.
WordMan
Harriman, Tennessee
I have never understood this logic. Why would you pay more for a smaller container of anything?
When you're dealing with a product like POR15, many adhesives, etc, which absolutely will go bad once you have opened them, paying a bit more per ounce for a smaller container saves you money in the long run when you don't throw large amounts of it away.
nbpt100
Massachusetts
If it were something that spoils in your refrigerator in 10 days more people would get it.
PugetDude
Nope. The original assertion was that it makes sense to buy the smaller container “even If it costs more”
To phrase it in your terms….
Cottage cheese… small size sells for $1.00
Large size selling for $.89. Neither one has a specified shelf life. You don’t know how long it is going to take for your family to consume it. Which one do you buy ?
4xdog
Santa Fe, NM
It comes down to likely wasted product.
If we stay with POR-15 as an example, a quart (32oz, 946mL) of the standard glossy black rust-resistant coating costs $60, or $1.88/oz. A pint (16oz, 473mL) costs $39, or $2.44/oz. The form I buy, 6 x 4oz cans (24oz, 710mL) costs $67, or $2.79/oz.
If one is going to use it all pretty quickly, get the quart. Or even a gallon. But for the projects where I use POR-15 I rarely use even a full 4oz can, and that only once a year or so. I'd end up wasting 80% or 90% of that quart can. That means I'd be paying at least 3x - 4x more for the quart than the tiny cans when waste is considered. The little cans are the best choice for the way I use POR-15.
MrSurly
East Texas
When storing the POR 15 or other coatings in 'paint-cans' use saran wrap but use a large enough piece that you can put the wrap inside the can, directly on the POR or paint so that there is a barrier between the paint and the air in the can. Once you have 'skinned' it with the Saran Wrap, the lid seal is pretty much irrelevant, as long as the can doesn't get moved or stirred.
zak77
Monson, MA
Blue painters tape for tubes of caulk. I've tried everything and the tape trick seems to be just as good as anything else but an added bonus is when you cut the tip off a little too much but you need a small bead, the tape creates a "new, fine-tipped" nozzle.
great white tj
Ocala Fl.
Will those things work on Gorilla Glue or super glue? I have learned to never buy a large container because you never get to use half of it.
I keep my Gorilla Glue in a window sill, it will not yellow and I found that it will last longer if I do this. I had a little bottle in a drawer for some time and turned in to a rock....
WordMan
Harriman, Tennessee
I think you've misunderstood the "cost more" part. It's not the a quart sells for $10 while a pint sells fo $12, but that the cost per quart for an individual quart is more than the cost per quart when buying a gallon (e.g. $5 per individual quart as compared to $16 for a gallon).
