Jzr756
So, I was really excited when I came across an old Kellogg American 331TV compressor pump I found on E-bay,I'm a Heavy duty equipment mechanic by trade and I remember working in a shop years ago that had a 331tv supplying the shop air,I had been really impressed by the build quality and especially how extremely quiet it ran situated in the corner of the shop.
Fast forward to a couple weeks ago I went ahead and purchased this pump sight unseen and after finally getting a hold of the seller to arrange for pick up I got a chance to ask what condition the pump was in, the seller said the pump made a ticking sound upon staring then went a way. he said he thought it was the centrifugal unloader that might need attention.Upon arriving for pick up I got the chance to hear it while starting and sure enough it made a noise while starting but it turned out to be more of a rod knock than a ticking sound, the seller insisted it was just the unloader making the noise .
I got the the compressor home, took it it apart , found the high pressure connecting rod bearing completely gone, crank shaft badly scoured and the connecting rod big end damaged.
New crank shaft is approx. 270.00 rod 90.00 gasket set 50.00 plus over 50.00 in shipping.
Should I count this as a loss and find a used Quincy QR-325? after the fact, I found from the forums that the quincy is pretty well regarded.
The differences I,ve found are the 331 has more displacement 4 3/4x 21/2 x 4" stroke and runs slower@ 350-668 rpm and is splash lubricated while the Quincy 325 is 4 1/2 x 2 1/2x 3" stroke runs faster @ 400 to 900 rpm and is pressure lubricated.
