Kent-Moore/Hinckley-Meyers Tool J-1127
BobsDynaflow
South West of Chicago
I am looking for a servo band adjustment tool for 1937 thru 1939 Oldsmobile safety automatic transmission/1938 Buick self-shifting transmission to buy/rent/borrow. Please let me know.
Thanks in advance,
Bob
engineer2
Chicago burbs
I don't have that one, but if you are ever looking for K-M Dynaflow tools, let me know. I also have a few more GM tools from that era I haven't identified.
Kent-MooreJ-1013Dial Indicator support
Kent-MooreJ-2590-4Clutch Spring Compressor Adapter, part of 2590 kit?
Kent-MooreJ-2592Primary Stator Assembly Tool, series 70
Kent-MooreJ-2595Installing & Removal Clip Trans Band
Kent-MooreJ-2596-1?Gauge, Converter Clearance series 70?
Kent-MooreJ-2596-2Buick Dynaflow Converter Gauge
Kent-MooreJ-2655Trans Access Cap Rem. Tool
Kent-MooreJ-3045Gauge, Converter Clearance Dynaflow Series 40-50
Kent-MooreJ-3045-2Part of Gauge, Converter Clearance kit Dynaflow
Kent-MooreJ-3081Primary Stator Assembly Tool, series 40-50
Kent-MooreJ-5338-1Converter Installer Tool, Dynaflow
Kent-MooreJ-5388-2Converter Installer Tool, Dynaflow
Kent-MooreJ-5804Trans End Play Gauge Buick Dynaflow, use with 5808
Kent-MooreJ-5808Dial Ind. Ext. Rod
Kent-MooreJ-5816Reaction Shaft Bushing Installer Dynaflow
Kent-MooreJ-5913Front Stator Blade Carrier Bush. Inst.
Kent-MooreJ-6248Reaction Flange Needle Brg. Inst.
Kent-MooreJ-6586oil delivery sleeve remover and installer, Dynaflow
Kent-MooreJ-6899Converter clearance gauge & plunger I==O==I looks like J-5899
Kent-MooreJ-7012Rear Bearng Spacer and Shim Loading Tool
Kent-MooreJ-7100Auto Transmission Reaction Shaft Oil Ring Compressor
Kent-Moore?J-7889Converter Pump Assembly Tool
Kent-MooreJ-6657Needler Brg. Rmv. & Installer
CharlieR
CharlieR
engineer2,
Do you still have
If so how much do you want for it & payment method.
Charlie
engineer2
Chicago burbs
I still have it. Tarnished, but don't look like it was used much, if ever. I'll try to clean it up a litte. Since you are a new member I'd like to get paid before shipping it. Should be cheap via USPS as it will fit in a small padded envelope. Where are you located?
