Keys locked inside HF Roller cabinet- Please help!
Amiroquai
Hello,
I literally just accepted delivery of the 44" US General cabinet 20 minutes ago. The thing is still on the pallet.
As I unwrapped it, the set of keys ended up inside the top drawer and I was interested in testing the drawers for operation. Upon closing the top drawer, the cabinet appeared to have locked itself and now I can't open any of the drawers.
I don't understand how this cabinet could have auto locked itself but it did!
I tried fishing out the keys but the they're too fat to fit through the gap on the upper portion of the drawer.
What are my options?
taco2001
I did the same thing. You can try and call harbor freight and get them to send you a new key. I ended up just drilling out the lock and putting in new lock.
Spacecataz
If you could turn the entire chest upside down it would come out of the drawer, and slide
out the back to the floor. ;)
Hiball
Missery
Are you sure that it's locked? Don't the HF boxes have tabs on the right hand side that you need to depress to open the drawers? What kind of tool box would lock without the key being turned?
LawnBoy-5247
Kansas City
Those barrel locks are very easy to pick all you need is a bic pen. Lookup some videos on YouTube they explain the process pretty well. I used the bic pen process on a toolbox that the keys had gotten lost for and it only took me 30 min or so and saved me the cost of a lock.
Sent from my LGLS991 using Tapatalk
Stuart96
Central ca
Right side under the drawer is the drawer release, assuming you didn't know this, if you did that is very odd it would lock itself.
A
Amiroquai
That's exactly what I was thinking. Otherwise, I would have been more careful with the key.
Judging by the build quality of this box, if the lock was preset to the locked position, I don't see how/why it would allow the drawers to be shut and set into the locked position.
A
Amiroquai
Not sure what you are referring to. I do not see any drawer release. Looked all over and under the handle tabs of all drawers, on both left and right sides.
Perhaps they changed the design?
taco2001
I don't think the 44" has the release tabs, at least mine doesn't.
You can lock the cabinet with the drawers open, then close the drawers and they will be locked. If you throw the key in, you'll be locked out (I found that out the hard way)
If it's still empty, Spacecataz's suggestion of flipping upside down is probably the easiest.
TNBurban
44" don't have the drawer release tab, at least the one I looked at in the store just this weekend didn't.
jakemac
New England
Flip it upside down. Gravity should drop the locking bar into the unlocked position enough for you to open the drawer and fish out the key.
Pull the drawer out and remove it. Then you can roll the box back over to sort things out.
It helps to have more than one person rolling the box. You don't want to drop it on yourself.
A
Amiroquai
I'll give it a shot. Nothing to lose.
Can anyone confirm the rotational direction to get this unlocked?
http://i.imgur.com/SkFjL8d.jpg
Am I going clockwise or counter clockwise?
A
Amiroquai
Thanks. I'll give it a shot if the Bic lock pick trick doesn't work.
Spacecataz
How dare you take my suggestion and make it better! :p
A
Amiroquai
Update:
I flipped the cabinet upside down and it undid the lock. I wasn't able to fish out the key from the top drawer due to overlapping and angles of metal surfaces so I had the two bottom drawers removed and flipped the cabinet back to normal orientation to let gravity do its thing. The keys were at the bottom.
THANK YOU ALL
for your prompt responses and help! I already had the drill ready and would not have thought flipping the thing upside down as an alternative.
This is a nice looking sturdy cabinet and great value. It's just a shame that it has such a design flaw...
Cope
Houston, TX
Amiroquai;6330747 This is a nice looking sturdy cabinet and great value. It's just a shame that it has such a design flaw...[/QUOTE said:
It's not a design flaw, that can happen with any tool box, and many cars.
G-ManBart
These kind of locks can be easily picked using a piece of flat metal cut/ground into a dagger shape...literally takes just a few seconds.
LB-1911
Northwestern Il.
Update:
THANK YOU ALL
For your info re photo's & Imgur
03-28-2016
Update. I guess Imgur is dead to Garage Journal for hosting because GJ has a classified section. Not sure I understand why that matters, but here is the email thread with Imgur CS.
Guess I will have to host the photos somewhere else and rebuild my page. I didn't use Photobucket originally because I have noticed that you can click on a photo hosted there and it will take you to the person's entire album and profile, which I think some people don't realize. Anyone know a way to prevent that?
Isaac K (Imgur)
Mar 28, 12:17
Hi there Sixfeet4,
Within our TOS, we do not allow the usage of imgur as a content delivery network on any site that has a section dedicated to selling. This is considered advertising. (much like eBay is blocked as well).
I do apologize for this inconvenience. I look forward to seeing you further within the community.
Best,
Isaac K.
Mar 28, 12:11
Bummer, thanks for the reply. What do you mean by "because there is a classified section"?
Isaac K (Imgur)
Mar 28, 11:59
Hi Sixfeet4,
Thanks for writing. Unfortunately that site has been blocked from hotlinking due to multiple instances of abuse of Imgur's terms of service. The terms of service can be found at http://imgur.com/tos. We don't allow hotlinked images being used as content for other websites. Because there is a classified section, we are unable to remove the blockage.
We suggest using another site that does allow being used as a content delivery network. I apologize for the confusion. Please let me know if I can help further.
Best,
Isaac K.
:beer:
