Killin' moles...
Lhorn
I have had excellent results using the poison pellets that come in the cone container. You just poke a hole in the path and drop a few pellets in. The dogs do not get at the pellets because they are under ground. Moles run up and down their paths they dig and cannot resist the pellets.
That's my 2 cents. Good Luck
I'm with Coolreed. I've had a mole problem for the 3.5 years I've been in my current home and the guy before me too. I tried 3 different types of traps, smoke bombs, spray and granular form repellant, castor oil and cayenne pepper, worm shaped poisons...nothing seemed to work.
I've been using the poison pellets and it gradually has worked. I got so frustrated spending hours after work trying to treat this problem and repairing the horrible damage they were doing to my lawn. Finally I gave up on the other stuff (costly and time consuming) and just started to religiously poison any new mounds or tunnels that came up. I wasn't sure it was working or not (and it's taken a while to see the effect), but I just kept at it because I couldn't give up and let them destroy my lawn. Last couple of years, the damage has been getting less and less. This year almost nothing. The difference is night and day.
It would be more satisfying to catch them in a trap and see for sure that what you are doing is working, but the proof to me is that my lawn looks great and is healing from the damage those little shits were doing. I think you just poison every visible tunnels and new holes/mounds and sooner or later they run across the poison and take it.
In addition to what ever else you are doing, try this. The poison is cheap. I put a tablespoon or so down every hole I make. Be patient, keep at it and give it time. I think this is what saved my lawn.
J Persons
Louisiana
Don't know about moles but the Victor easy trap works well on gophers. We have a Farmers Co-op here and they are about $6.00 each. You will need to get at least two of them, face in opposite directions in the burrow, and tie them to a stake. With the first one I had, the gopher wasn't killed, and dragged the trap down into the burrow and I lost it. Tie the trap to a stake with a length of wire stopped him cold. I'm usually successful after about an hour or so.
Here's one advertised at Home Depot.
http://www.homedepot.com/webapp/wcs..._mmc=shopping-_-googlebase-_-D28X-_-100336751
OneAkela
Get rid of the grubs. Use milky spore. June-July is probably the right time to put it down. Do one application- if there are enough grubs to sustain a mole colony, you should be set for the next 20 years...
Andy Griffith
Western WA
If one has a thriving backyard bird population that has been built up over a span of 20 years, and one puts down milky spore to get rid of the grubs, how might this affect said bird population?
Andy Griffith
Western WA
Alright, I have tried just about everything on these vile creatures and the only luck I've had is killing one that ran out in front of my truck as I was going down our road. Including the much heralded victor spike trap which was a waste of money.
So I have put one of the vibration thingies in the ground and have just ordered an easyset mole eliminator trap from Amazon to give that a try.
Finding a main tunnel has not been easy. I can find what look to be feeder tunnels that literally perforate the yard, and I can find connecting tunnel intersections (large mounds), but finding a repeatedly used main run has been difficult. We have a tremendous amount of over-growth ground cover around the perimeter of the yard and out into our surrounding acreage and I suspect they are coming into the yard from there.
Jackfre
N CA
Well, I don't normally tell this story, but see in' as how it is only you guys...About 35 years ago I had a mole problem and came home after having a couple brews after found the yard all torn up. The Missus had insisted on the have a heart route. She wan't home so I went up to the shed, got my big cutting torch out, put the big rosebud tip on it, set the flame just right, snuffed it out and buried it in the hole. I let it run for a bit and went to get a lb of gun powder for a fuse. Well, I ran the fuse, touched it off and I swear, I had flames coming out of holes I didn't know were there. I killed the gophers and also blew the yard up. After all I went through with those darned gophers I was pretty pleased. She on the other hand....;)
When I have to shoot anything in the yard and not alarm the neighbors I use my air rifles. I have a really nice spring piston air rifle that is just the nuts around the place. It's gotten so now the neighbors come over to ask me to help them out with varmints. We just moved to the place last summer and had a heck of an infestation of ground squirrels. I've taken care of them and not scared anyone while doing so. Check out www.straightshooters.com for info on air rifles.
