I'm not going to bash the product as I feel that it's a damn good one. I have recommended more than once to use it in the garage to cover walls, like OSB, which ***** it right up. In my refurb thread, I have used it alone with great results, until yesterday.
I touched a few spots and put 2 coats on some fresh OSB. I went out to the garage yesterday (been too hot) and found out I had a slight problem.
As you can see, the older Kilz primer has yellowed in the past 1 1/2 years. It's not from nicotine as I do not smoke but I do have a woodburner so some smoke does get in the garage. I don't know if this is normal for the primer or not. I will from now on make this recommendation, top coat your Kilz primer.
If anyone has used Kilz-oil based primer alone from my recommendation or seen that I used it in my refurb, please top coat it to keep your garage looking nice. I apologize and I'm sorry for the bad advice, I didn't know it would yellow over time. It looks like I will be repaint almost the entire inside of my garage over the winter.
