No, but judging by the single photo, it appears to be a wire cutter using sheet metal for the body and handles, maybe to reduce weight or provide a high leverage design.Anyone know what this is?
I seached and can't find any information on it.
Says: King Cutter Corp. Chicago, ILL. Patent Pend.
No other marks on the handles or on the other side.^ I am completely at a loss on this one. I can't find anything even close on the web. I've sent out some inquiries. No idea if I'll hear anything back on this one.
Any other marks on the unit other than those in that one photo?
We use regular aviation snips for that--and a welding jacket and face shield. Those straps can have some loading on them.I'm wondering if perhaps it was outsourced. Hopefully I'll get an answer back. Might be a strap cutter - steel banding straps used to tie stuff up on pallets - the the gouges on the jaws kind of belie that theory. Whatever its intended use, I'm guessing that it applies a good amount of pressure to the jaws.
Yes, I have it at home soaking in Evaporust.I guess the next question to ask, as to what it does is: Does the OP have the tool in hand? Is it compound action? Is it ratcheting? Can it take a finger off?
looks like the right mechanism.Has a lever mechanism that looks similar, assuming cams inside the cover. Inventor in Chicago. Talks of sheet metal construction possibilities.
I'll try it on barbed wire this weekend and let you know,I believe it's for cutting multi-strand barbed wire. I seem to recall we have one on the farm years ago when we had some barbed wire up before we went to electric fence. The King Kutter brand at least one incarnation of it can still be found on some short line farm equipment like brush cutters and box blades. I seem to recall at one point there was something to do about separating brands and hence the c and the k names.
