One of the Amazon reviews says they are M5 socket head cap screws. I would assume the screws have 0.8 threads (0.5 threads are pretty rare). I couldn't find the overall screw length spec online.
Awesome! Unless you put loctite on those screws immediately after you buy the tool, your sure to loose one. Obviously I forgot. Thank you for the info. I’ll try that type, see if it works & report back.
They are actually 3mm screw 9 mm long. Could not find a socket cap screw that size around here, but ace had the correct size, just was in a Philips head, which worked fine. Put the loctite on and I'm all good. Thanks again
