today only
This is a pretty good deal on a Klein 'pass through' type Cat 6 crimper with 20 rj45 jacks. If you are ever thinking about installing IP Cameras, running some new network cable, etc - you should take a look
In case you didn't know, 'pass through' type crimpers and jacks allow you to insert each wire into the jack and it then comes out the end where you can visually check that you have the wires in proper sequence. You then insert the jack into the tool which crimps the jack onto the cable and cuts the ends of the wires off. It really makes the job a lot easier.
https://www.homedepot.com/p/Klein-T...CAT6-Data-Plugs-20-Pack-M2O40903KIT/311293503
