Knee Pads & Kneel Pads?
Bolster
Mexifornia
I'm rebuilding a house and find I spend a lot of time on my knees...tile, baseboard, flooring...it's all so dang low! You'd think in this day and age, we could make floors that were waist level and easy to work on, but, no.
I own four sets of different-branded knee pads and don't like any of them. Mostly they take any opportunity to sag off my knee and settle around my ankles (which don't need padding) leaving my knees unprotected.
Kneel pads are a bit of a hassle because you have to keep moving them, but...maybe they're better than knee pads? At least they don't glom onto your ankles.
Do any of you have good experiences with knee pads, and if so, can you please share the brand or model?
strutaeng
Dallas, TX
I bought these many years ago when I was doing a lot of rebar scanning on a stadium concourse concrete floor. I previously had the pads from the big box stores and hated them.
I've since used them for DIY projects around the house like flooring and baseboards like you. I recommend them:
Sellstrom S96110 Ultra Flex III KneePro Knee Pads for Construction, Gardening, Flooring - Pro Protection & Comfort for Men & Women (Multiple Colors), Orange/Gray https://www.amazon.com/dp/B005I4PT18/?tag=atomicindus08-20
bonneyman
Desert SW
I have a 20 year old pair of knee pads that worked decent when they were new. Nice molded foam core with a hard plastic knee "cap". For those occasional times I needed some help they were fine. But the velcro attachment bands got all stretched out and now they're basically unusable.
Likewise i snagged an ACE brand stadium cushion that works great if you're working in one area for awhile. But having to move it is a pain.
So, no help from me on either issue. Sorry.
loganb
Omaha, NE
I Have 2 pairs like this from Big Orange, 2 different brands but appear identical. For me I like a single, big wide strap more than 2 straps
There are also pants with built in knee pads pockets, they're not as padded as ******** pads, but they're always there. Duluth Trading are the ones I'm familiar with on the built in pockets, but others exist
KnurledNut
n/a
These are incredible, can wear them all damn day.
Sellstrom
A little different version of these are used by miners underground. Super comfortable for work on nasty, wet, hard, hot/cold, sharp, etc. surfaces. I have a pair.
I use Crain poly-skin for delicate surfaces and they are pretty good but can get uncomfortable for really long periods.
I wear pants with knee pad inserts daily and have gotten so used to them I forget they are there. Perfect for many jobs.
bcradio
New Mexico
Ordered some of these. Thank you for the suggestions
mrvm
PA
Never tried these but they look 👀 interesting
crewchief888
NW indiana
best ones i ever found were actually a skateboard/inline skating knee pads from dr bone savers.
they didnt hold up well to grease, oil. and diesel fuel.
i looked at a pair of milwaukee brand knee pads a while back, but passed on them
alinc100
Dearborn,MI
Not cheap ,but neither is knee replacement. I use the AP16's ,they don't ride down often,when the straps are right and I criss-cross them on my calves. The 714's I have a feeling stay in place better,but significantly higher. https://www.amazon.com/dp/B07DM7ZGCB/?tag=atomicindus08-20
As a carpenter,doing commercial interiors I go from floor to midwall to ceiling in several rooms with acoustical panels,aluminum trim and markerboards,usually moving between the floor and a small painter scaffold,or ladder. If I was to start over/buy again I might opt for the taller,more expensive ones ,but at this late stage in my career the AP16s will last .
bluedog225
Texas
I use appropriate foam from whatever shipping. Lots of kneel pads laying around. Even 3/4 polyiso works for a while.
I used my old volleyball knee pads for decades as a homeowner. Tried to upgrade to some nice hard shelled ones, hate them on hard surfaces, I feel wobbly. Another pair fell down.
Now I mostly use kneel pads, and two if I am moving around a lot.
AEAdam
SE PA
I have the cheapest gardening knee pads. Single elastic strap goes around your lower leg. Used them for the exact same job you are doing. I was screwing down plywood subfloor.
I bought trousers with the (expensive) knee pad slots. Hated them.
I also use a closed cell seat cushion as a kneeling pad.
I love tools and gadgets and have spent the absolute least for this sort of stuff.
GeoBruin
I'm in the exact same boat. I use the $4 knee pads from Harbor freight after paying a lot more and getting fed up with other hard shell type models. The problem is, you ad weight to them, they want to fall, so you have to have more straps, then they have to go above and below the knees, so they have to articulate, but then they weigh more, and so on.
The cheapies are so light, I forgot I'm wearing them. One strap to close, they're quick to put on and take off. If I lose or destroy them, they're easy to replace. Hard to beat
mike93lx
Richmond, VA
I hate wearing knee pads. They are either too tight or move around a ton and make me sweat too much. I've been using kneeling pads a lot and much prefer them. Mine are from a bunch of cold shipments that my father had come through his work. They're the perfect size for kneeling, very durable and I got a ton of them, so there is always one available. I've also used the 2x2 foam squares that are available at HF for under foot cushions
AreBeeBee
Wisconsin
I use both — a set of knee pads for when I know I'll be moving around a lot and also kneeling. And I have a "kneel pad" for when I'll be in one place working low.
Why have both when knee pads cover both situations? Well, the kneel pad is more comfortable but as many have noted said above, it's a PITA when you have to be here and then there and then move over to a third place....
Pretty much all the kneeling pads are equal (at least those I've seen and tried). But there's more diff in comfort and durability with the various styles and brands of wearable knee pads. Bottom line? The more time you spend on your knees at work (yeah, yeah — I know), the more comfortable they need to be. So try on many and spend appropriately.
39 LaSalle
TN
I've tried knee pads, but as others have mentioned I've had issues with them slipping, feeling unstable, etc., etc., etc. and I just don't care for them. Picked up a Husky kneeling pad at Home Depot and love it. Yeah, it's a minor pain to move it around sometimes (mainly use it for working on cars, toilets, and so forth) but the benefits are worth it to me vs. using knee pads.
Copymutt
Colorado
Stuff a chunk of ensolite pad in it. Unlike **** pads that fall down in less than 5 min. It stays there!
ecotec
My favorite kneeler pad is the QLT from Marshalltown. I have had mine for years. One of the handles is broken, but not broken off.
Bolster
Mexifornia
Many thanks for the recommendations, my friends. Now to pick a solution or three from the options above.
("Promotion Pads," LOL, will say no more about that!)
Kkmk
I’m sold on pants with knee pad pockets in them. I dont use proper knee pads though, just a few pieces of neoprene cut to fit, dofferent thicknesses to suit. Depending on your legs, you may need to hoist them up every time you kneel down though.
I can go from climbing stairs, to kneeling on steel mesh a dozen times in as many minutes and this works best for me.
Skip the ones with built in neoprene pads. Pretty much useless to start with, and after a few washes there’s nothing left.
BSWS
Tucson AZ
While working for a living I had bought at least 6 different pairs of knee pads and don't think I ever used any of them for more than an hour before giving up. My biggest issue was the uncomfortable straps behind my knees. Now, with even older knees, I kneeded to go down in my crawlspace to crawl around on some sharp stones while doing a project. My wife was headed to Walmart and I asked her to pick up a cheap set of kneepads...I was desperate. I don't know why, but I must have read the installation instructions and it mentioned crossing the straps from top to bottom, sort of forming an X behind my knee. I didn't believe it but it made a huge difference. I've worn them a few more times and have never had any discomfort yet.
I don't know if all brands recommend this crossover because I probably never read the instructions before. But here's a link to the cheap pads that are continuing to protect my old knees.
Chipm
Georgia
Mechanixwear. The straps are 2" neoprene instead of the flimsy 1" elastic ******** most other I see. Hard front but flexible.
Mr.zippy
Wyoming
This..... but all 4 of my daughters played HS volleyball, so I had a lifetime supply of the damn things!
