JonnyMac
I have a Japanese chefs knife with Damascus blade (from memory its called a kasumi). Ive noticed a few chips in the edge. I have a wetstone whhich puts a great edge on the blade but I wouldnt mind resharpening it so the imperfections are removed.
ive never dealt with this steel before and im wondering if its wise to use a bench grinder with a relatively smooth grit to take the edge off or is the hand method of an oil stone/file/other method the best route to go???? Thanks...
. I've had to remove chips as big as 1/4 inch and also use a belt sander. Mine is not watercooled so I use finer grit , profile a bit and water quench every few seconds ( paranoid about affecting the hardness )
