woodstockva
Hey Everybody
I wanted to put together a video to show how the new Knipex Hose Clamp Pliers actually work. The pliers are based on the Cobra frame w/a unique jaw design that has two pivot points on either jaw that will spin 360 degrees. This allows you to grip onto a spring type clamp and remove it.....while turning the pliers left/right in order to get around obstacles.
There are still going to be many places that these are not going to work (clearance issues).....but I run into the same thing with the cable operated hose clamp pliers not fitting in simple places such as under the power steering fluid reservoir. So, no one pair of hose clamp pliers is always going to get the job done....but these will work in many situations.
The 2nd feature that they have built in the jaws, is the ability to grasp onto the hose & remove it from the fitting. This will save a step, and you can replace things (such as a heater hose) with just one tool.
Check out the video to see how the work!
<iframe width="560" height="315" src="//www.youtube.com/embed/tLk9gXezfeY" frameborder="0" allowfullscreen></iframe>
