Knipex Electrical Installation Pliers?
surgeofprotection
Saw a pair of knipex 1396200 6-in-1 electrician installation pliers. Are these better than getting separate combination, needle nose and crimping pliers? Or is this more of convenience?
hautpot
California
I have the Euro spring VDE and American dipped version. They are excellent pliers and are the polar opposite to traditional Linesman Pliers.
The Installation Pliers are narrower and capable of quickly stripping insulation, whereas typical Linesman Pliers can cut harder and have a fish tape puller. The cable cutter feature is really invaluable and the tip is not serrated which helps prevent marring wire.
The spring design is good and cumbersome. It will keep the jaws open a bit, but cannot fully close, this makes it slightly difficult to store in a bag.
Brownsfan
Cleveland Ohio
r_olson_06
SD
Had these for 3 years now and they are pretty decent. They don't do the best job in anyone task but are versatile
Sent from my XT1030 using Tapatalk
jeffmoss26
Cleveland, Ohio
I bought a pair when they first came out (the normal, non-insulated ones) and I don't think I have ever used them...lol
Roobaix
White Plains, NY
I like them. Most of the wire stripping I do is for different gauge wire than they are capable of though.
I prefer the Klein All Purpose Plier. A little larger but they have more wire stripper sizes and a spring loaded handle. The downside is they don't have a lock for the handle so I wrap a piece of Velcro around them to keep em' closed when they're in my pouch.
marcone
Romania
That is one thing keeping me from buying them, they can't strip 4mm thick wire.
Another is that even if I have a 4 plier set-up for electrical work, with the built-in features of these pliers I would still need 3: proper stripper, this one and an ordinary pair of pliers to hold the cable bundle while twisting it together- I like to solder my connection points, not a fan of mechanical connections.
kylefitz
Kansas City, mo
I think some of you guy might be missing the point of these pliers. They are for installing residential electrical systems in homes. That's why they have stripes for 12 and 14 ga wire only.
marcone
Romania
4mm is not uncommon in residential electrical systems in Europe.
