Knipex installation pliers
ishiboo
Oshkosh, WI
A pretty specialized tool...
How are those able to cut 35mm cable as listed in the description anyway? Are they much bigger than they look? :)
djb2
Redwood forests
It should be 35mm^2 what is like .263 of an inch conductor or 0.378 of an inch with insulation.
That's a pretty hefty cable, and the description states "diameter". It seems likely they mean 3.5mm diameter.
But at almost $55, this is hardly a hot deal.
djb2
Redwood forests
No...
Max cutting capacity:
*cable - Al + Cu 15mm (.59")
The text in question was "reducing the effort required to neatly cut through copper 35-mm-diameter cables by an amazing 70 %."
It's not talking about the maximum diameter of the cable that may be cut. Just the targeted diameter.
Danglerb
SoCal
Huh, specialized tool, but seems like selling fast. Seller is in the UK, so maybe something market specific?
mattyrattypoo
I bought a pair from this guy a while back. Love them! The version with the spring is not available in the USA and is probably why they are selling so quick.
r_olson_06
SD
These are a very well rounded tool. They are not specialized unless you call electrical specialized. I use them almost daily and no complaints here. If you do alot of cabling or controls work they are great.
Danglerb
SoCal
Specialized in the sense of doing a lot of electrical work, doesn't suit my use because I have too many types of wiring chores with vastly different gauges of wire, plus I already own a cheesy GardnerBender all in one type pliers.
