Loscaldazar
- Joined
- Feb 23, 2013
- Messages
- 2,385
So my Knipex Mini Bolt cutters have a dent in their cutting jaws now! I was using them to cut antennae wire (copper coated steel, about 30% steel). Failed on the first cut. Only used them about two dozen times before this. These should have been able to handle a very thin (3mm) 30% steel wire, no?
On top of this, when I first got them, they had a chunk missing from the top of the cutting faces, but I didn't think much of it because it didn't affect the cutting performance. Usually don't care too much about small cosmetic defects.
Suppose I get to see how good their warranty is... ***** because these are the 71 32 200, which are comfort grips, return spring, locking, and notch. Very expensive....
The first picture it is easy to see the defect on the tip that was present from the factory. The second picture you can see how the jaws were dented in by the wire (note, the large gap at the bottom is the factory notch, not what I am talking about).
and document the deterioration of the cutting surfaces.
Holy ****!
