knockout size holesaw or?
jdsac
Can anyone point me to a knockout size holesaw? I need to add to a 10x 10 junction box & can't find one small enough. Other ways to do it? Greenlee punches are expensive for a one time use.
Thank You!
Terry D
St. Louis, MO.
What size conduit
1/2 conduit and connectors is 7/8 hole
3/4 is 1 1/8 hole
1" is 1 3/8 hole.
Holes saws are your cheapest route. But they tend to wander and make to large of hole.
You can get a unibit for 7/8 or 1 1/8, but they are not cheap.
Anything to make a decent hole is pricey
You can buy j-boxes with KO's in them
Sent from my SM-G960U using The Garage Journal mobile app
7635tools
Southeast Wisconsin
Generally with emt conduit you go a 1/16” less on hole saw diameter for a tighter hole on the connector. Although I haven’t had an issue with a 7/8” hole saw for 1/2”, I do have better luck with 1 1/16” for 3/4 and 1 5/16” for 1”.
Pingel85
Green Bay, WI
Terry D hit it on the head. If you buy an electricians hole saw kit it would be 7/8, 1 1/8, and 1 3/8 for 1/2, 3/4, and 1” respectively. If you have a specific size conduit you’d be looking for just let us know and we can get you the correct size hole.
sky jumper
if all he needs is 1 use then a $2 wood spade will work. drill a 1/8" pilot hole and go to town on that s.o.b. yeah it will destroy the bit... the $2 bit... but it will make the hole just fine.
nadogail
Coronado, CA
I have been known to borrow or rent a tool when I needed one for a "One Time" use. If possible I return the tool equal or better than it was when I received it. If the tool was loaned to me without a charge, I often include a "Care Package" with the tool or shortly there after.
Pastry is currency.
AP514
Pearland, Tx
I JUST DID A 1-1/8 HOLESAW FOR MY 3/4.
I used wood block on back to help keep holesaw from wandering(as suggested here on forum)
reader2580
Minneapolis, MN
Harbor Freight has a step bit set for $20. Menards also sells a Performax step bit set for $20.
I am doing a pretty big electrical project right now and I have used both hole saws and step bits to drill holes in electrical enclosures. The step bit is definitely easier, but not big enough for large conduit,
Crazyjake8493
Upstate NY
A step drill bit (even a cheap one) would work just fine for adding a knockout or two. Most go up to 1-3/8". If you plan on doing more in the future, I'd look on ebay for Greenlee punches. I needed two sizes to punch some holes in a stainless steel brewing kettle, and I found a listing for 8 different sizes including the two I needed, for about $30.
Terry D
St. Louis, MO.
Knockout punches are by far the best way to make a hole, especially when you get to the larger sizes. I know they make the cheaper unibits or step drills, and they are probably fine for a small amount of holes, but at least the amount of times I use them, it would not be cost effective to have to keep replacing them. Keep them lubricated when drilling and they will last much longer
rburke65
Canfield, Ohio
Stop and ask an electrician, when you see a truck, if he will punch it out for you. Most times they are happy to help.
Norcal
I prefer a KO punch, but in the case of the OP, a hole saw is going to be the most cost effective solution, and most people would find other uses for it.
Terry D
St. Louis, MO.
I agree, in post #2 I said a hole saw would be the cheapest. But as you know, contractors/electrician like us spend a lot of money on stuff to make holes
sparky 1971
Central Iowa
I have used many hole saws over the years. They work just fine. I now use the carbide cutters up to 1-1/4", and the ko set for larger. Varibits only get used to make a hole bigger.
DeeKay
Colorado
Before I had a KO set I preferred step bits to hole saws( for smaller stuff). Just make sure you pilot drill because that's always the first thing to go on them.
