Knotty pine in a garage
Bsheffer
Frederick, MD. 50 miles north of Washington D.C.
I have a stone house and am finishing the garage. 26 x 26 with 10 foot ceilings. At about a buck per square foot, tongue and groove knotty pine looks like an interesting option. I put this in a living space over a garage at my Lakehouse and it looked great. Couple coats of poly and the stuff should be good for a long time. I might do one 10x25 foot wall in wood which I figure would cost me $250 in material. Compared to the time it takes me to hang and finish drywall, it seems like it might even be a cheaper solution. I remember installing the stuff and it goes quickly and rolling the poly was a breeze. With the stone house, I think the wood might add a nice alternative to the abutting drywall walls as well. Thoughts?
Jazz1
Thunder Bay On.
It would look great, No mudding but sanding between coats...I did half interior of house in pine. It is very bright even with a satin clear. I put pine on a 3' area at man door in garage with leftover.. I rather hang tongue and groove than paint!
lakeroadster
Central Colorado
That would be a great look.
We live in a "sleepy little mountain town" and the closest Home Depot is in Vail Colorado. Last time we were there they had 4' x 8' panels of unfinished pine, T1-11 tongue and groove panels.... I have been thinking along the same lines as you... hang it, cover it in pine pitch, and be done with it.
kaymccampbell
Upstate New York
Sounds pretty, so long as you're not planning on welding. Been to this well, it smells smoky.
It is very uncool to be putting out your wood whatever with the firehose.
More uncool if it's the local FD doing it.
jaker10
Bartonvillle Illinois
Have knotty pine in my whole house. Looks good if your not living there, if your
just stopping by for a visit it's like living in a cabin. Dark and gloomy. Maybe on one wall it would be ok.
FTWingRiders
Central Ma
I've got no problem with it..
[U
[/URL]
jimgood
Marshall, VA
We used it in the ceiling of our barn aisleway and it seems to be holding up well. It's been up for about 10 years. There's no insulation between the ceiling and the loft floor above it.
Cyberbear
California
A traditional wall covering like knotty pine is a good choice and provides a warm and homey look to any wall surface. When exposed to light the pine will darken over time, even with a clear coat, especially if covered with varnish as back in the day, depending on the look you wish to achieve. You may have to expect some warping over time but that can be reduced if you install the wood soon after obtaining it, the walls will help to hold it in place as the pine "adjusts" to it's new home. Insulating the exterior walls will help as well.
justanengineer
Motor City
JMO but mine was likely installed in the 60s-70s and still looks pretty good despite a ton of abuse that wouldve destroyed drywall. The walls are a medium gold and the ceiling is also paneled in a dark brown. Not sure if its stained or varnished, but oil spatter from machines simply wipes off months later without staining. Its not dark my camera just *****, my eyesight ***** too but I can easily read a machine dial or mic in there without local lighting, and to be fair I've only got 8 4' T8s overhead in there (2 fixtures, 8' long 2x2 bulb configuration) for lighting 24'x24'. Whatever the top coat is on the paneling it reflects a ton of light, I have to be REALLY careful taking pics bc of light coming in the windows (I never use a flash).
I like it, but I also like a home with a bit of class rather than the usual tacky white drywall. The paneling fit the classy old feel of our house perfectly IMO and we worked hard to keep those original touches renovating the house (sadly never finished the garage), which is why it sold in <1 week with multiple offers above list and a fully book viewing schedule (2/hour every hour 7-5).
lakeroadster
Central Colorado
What is pine pitch?? How thick are the 4x8 sheets??
Sheets are 3/8"....
As for Pine Pitch... I could have sworn I read somewhere that folks used to paint their barns / cabins with pine pitch... there are a lot of very old barns & cabins out here that the exterior wood is just stunning.
boomer12831
northern New York
I used it in my house garage about 3 1/2' up from the floor then finished the top with a couple of pieces of trim. I have gotten a lot of comments on it and plan to do the same on my workshop sometime this winter. Ed
Milton Shaw
A freestanding garage it is ok. But if you are attached to a house or have living space overhead, most codes require fireproof wall (drywall) between the rooms. Like the look of it and have it in my kitchen.
SteveCh
Pine pitch is extremely sticky sap, and it will gradually lose moisture to become so sticky it requires something like paint thinner to remove from one's hands or anything else. Over a long time, I've seen it become hardened, but really warm air, such as on a hot day, can sometimes lead to it becoming sticky again. I've found that if it gets on my work gloves, as when handling pine firewood, the only thing I can do is put some paint thinner on the gloves and run them through the wash. That will remove most of it, though I have several items of clothing here [now dedicated work clothes] from which I could never get it all out.
K'ledgeBldr
Johns Creek, GA
I was beginning to wonder if anyone was going to get there-
One maynot like doing drywall, but it could save your life.
ziprun2005
Greater St. Louis Area
Ah, so this is an interesting point. I'm thinking about doing this on my attached garage, but only against the exterior walls. They didn't insulate them during the original construction and I'll be pulling down the drywall anyways.
The tricky part seems to be finding 10ft boards in my area. I keep running into stores that stock them only at 8'. Admittedly I need to look harder though.
FTWingRiders
Central Ma
I like the look of pine and drywall. If I was ever to do a log cabin, the inside of the exterior walls would be wood, but most interior walls would be drywall. I say mix it!
FTWingRiders
Central Ma
Find a local sawmill, I used to own a woodmizer and did sawing,always had guys looking for rough cut pine boards. Tho with the woodmizer, it came out real nice right off the mill.
lakeroadster
Central Colorado
Have you thought of a wainscot approach, maybe using steel panels, or something of that sort, for let's say the lower 3 ft of the wall?
Or maybe using the pine, but kicking it at a 45 degree angle along the the lower 3 ft of the wall?
Breaks up all the vertical lines.
ziprun2005
Ah, now that's a great idea. That 45 would look sharp...kinda like a chair rail look. Time to do a little sketching and calculating...
77Mini
Ontario Canada
Depends on what you are planning on doing. It would look great but if you are planning on welding etc then its kinda like installing kindling.
yossarian19
People's Republik of Kalifornia
Well, being wood it won't be as well rated for fire as sheet rock. I'd still probably do it, though. BTW - good job finding a stone house in Frederick! I thought it was all town houses & condos by now...
When was your place built?
We need pictures of the garage, too :)
fourjeepin
Atlanta, GA
I recently put it on the ceiling of a room in my basement. I primarily went with it to keep from having to hang Sheetrock on the ceiling. I plan to paint it white to keep the room bright.
Hankoh
Northwest Ohio
It may be possible to use wood and still pass local fire codes (depending on the codes and local authorities). Do a search on "Class A Intumescent Fire Retardant Varnish" - there are a number of manufacturers. Intumescent paints and varnishes are finishes which essentially puff up in a fire, sealing off the flammable material from flames. I develop and manage nursing home properties, and we can use wood in a nursing home if it is finished with a Class A intumuscent finish. Large quantities of wood cannot be used in a nursing home, hospital, etc. without such a finish - and healthcare codes are among the toughest codes around. These finishes are expensive, but it is an option that may work. In our case the walls are covered with fire rated drywall, then wood applied over the drywall and finished with a Class A finish. This passes code for us.
Outlander
Quebec, Canada
Not exactly a log cabin, but pine & drywall is what I have in the cottage.
View media item 57099
Yes, you caught me with Christmas decorations still up. Mrs Outlander and I are getting to that today. Honest!
floyd
MD
I used shiplap inside and out on my building. I am very happy with how it turned out.
Bsheffer
Lake, my thought would be to run the stuff horizontally and therefore would not have the vertical lines. This same pine is run vertically in my Lakehouse in one area and horizontal in another. Seems it would take a ton of blocking to install it vertically.
yossarian19
Yoss, sounds like you know the area. There are only a few stone houses in the hundreds of historical homes that comprise the historic district. Mine was built in 1930.
Oooh, nice. The historic district has a lot of character, more so than Potomac, Bethesda or Rockville have left & not all that far to DC. I don't know Frederick all that well but I've always liked the old town.
I grew up in Montgomery County (I know, I know...) and went to school over in Frostburg, still have plenty of friends and family in Maryland.
jherb10
York, Pa
I went to Frostburg also. Graduated in Spring 1990
scotty t
indiana
i just did a corner in my garage with leftovers from my patio.
