Knoxville Garage Renovation
TCB
Knoxville, TN
Hi everyone,
Since this site gave me such great ideas and inspiration, I thought I'd share the before and after of my recent garage renovation. I'm lucky to have a great space to start with. The garage is a standard 3-car appx 23' deep x 30' wide with a 9.5' ceiling. One the right side, there's also a space that's inset about 2', making that side 25' deep.
Since I wouldn't qualify even as a "shade-tree' mechanic, this space will be used mostly for detailing, a workspace for various home projects, and as a nice, clean space to see as you enter the house.
Here are the "before" pictures. I did do a couple of things before these shots were taken. Specifically, I replaced the 2 aging T12 light fixtures with T5HO and got the HF rolling cabinet/top chest combo in place of 2 of the white cabinets like the one to the left of the toolbox.
T
TCB
Knoxville, TN
Here are the changes I made.
The walls were painted with the ubiquitous GJ light gray/red stripe/darker gray combo. Thanks to everyone on here for the great tips on how to paint the stripe! I did discover that the base colors were bleeding through even after 2 red coats, so I went over it with a gray primer before going back to red. That did a great job of evening out the colors. If anyone is interested the paint colors are:
upper: Sherwin Williams SW6001 "Grayish"
lower: SW6003 "Proper Gray"
stripe: SW 6868 "Real Red"
I used the SW Duration paint in a semi-gloss finish.
T
TCB
Knoxville, TN
For the floors and cabinets, I decided to go with Premier Garage. A neighbor had his floor done by PG a couple of years ago and it seems to be holding up well. The PG crew completed the job in 2 days. The first day was grinding the floor, fixing a couple of cracks, laying down the base coat, and spreading the flakes. Day 2 was scraping up flakes that didn't bond and covering with the sealant. They also added the trim strip to transition from the epoxy'ed section to the bare concrete (which they also sanded and sealed)
The color is called Graphite with 1/8" chips
T
TCB
Knoxville, TN
The cabinets are also from Premier. The right side has four cabinets (1 24" and 3 48") in the inset space. All of these are 91" tall.
The 24" cabinet makes a great space for detailing supplies, while the others will be for general storage. Trust me, they wont be that neat for long. Right now, I've only put in the relatively clean stuff that the boss let me keep in the dining room during the project. The rest is in the crawl space . . .
For the workbench, I originally considered using Premier's basic laminate countertop. After looking around here quite a bit, I decided I liked the butcher block look. Unfortunately, Premier's supplier wanted an extra $1K on top of the base price. :eyecrazy: I looked around a bit and found an 8' x 25" x 1.5" piece online at Lumber Liquidators for $259 with free shipping to the store. I cut it down to fit my 6' space and the Premier guys installed it for me. I really like this look, especially since I'm not going to be banging on any transmissions or welding in here.
T
TCB
Knoxville, TN
Finally, I wasn't sure what to do about my ladder. Since it's needed in the house fairly often for changing light bulbs, etc I wanted it in the garage where it would be handy. Previously it was up front near the old shelves just leaning against the wall, but I was always worried that it would tip over.
I thought about using the ladder hooks that screw into the wall, but wasn't sure if they would support the weight, since only 1 would be in a stud. I decided just to keep it on the floor, but use a webbing strap & buckle to keep it upright. Its in an out of the way corner, and I don't have to worry about it falling over onto the car.
MajorLeeGassole
Fairmont, WV
Amazing transformation! I love how everyone has started to REALLY point out the color schemes lately. Too funny! Did you have the same issues I have? Level floor + level threshold = rain in the garage? I noticed you are using the rubber strip along the entrance. Do you find it to be a pain when trying to sweep out the garage? I do not have a floor drain, so that would just make washing the floor more of a pain trying to push it over the strip. Better than rain coming in!
dubber
Canada's Capital
Wow! I knew i would like this garage. Looking great. Those cabinets are perfect and that little touch with the ladder is great.
EDIT: I spy a nice Red fire extinguisher that would look great mounted up on your wall :)
patent pending
Charleston, SC
That's a great transformation...floor turned out killer, cabinets look awesome, and the colors help out a lot.
Any info on the trim strip for the floor? Looks nice and wide, which is what I'm looking for.
Rockuf8
Northern NJ
Came out nice, looks nice and uniform, and I like that you did one larger stripe.
In the first pic you should've fixed that crack in the drywall prior to doing all that painting. :p
The upper and lower sections look almost like the same color, a shade slightly darker on the bottom would've helped distinguish between the two better.
Love the floating cabinets, plan on doing that with the new cabinets I have on their way.
T
TCB
Knoxville, TN
Thanks for the kind words!
Yeah, I've just gotta find the bracket that goes with it. Its around here somewhere. :thumbup:
T
TCB
Knoxville, TN
It looks better now than before I started! I did do some quick repair/sanding on it, but that's about the best I could do. I guess I succumbed to "its-just-a-garage" :)
They are pretty close . . . only 2 shades apart as you can tell from the paint codes . . . but the contrast is a little more apparent in person than in the pics. The next shade was quite a bit darker, and I was worried it would be too much since I knew the floor would be pretty dark.
Rockuf8
Northern NJ
Not surprised the colors look a lot closer in the pics.
patent pending
Charleston, SC
I'm pretty sure its the Tsunami Seal. Personally, I didn't have a problem with water seeping in under the garage door, but the strip just made a better transition from the epoxy to the unpainted concrete
Awesome, thanks!
My need for it is two-fold. I got water coming in sometimes AND the transition from my epoxy to unpainted concrete looks terrible:lol_hitti
