yellow05wing
I'm in the process of putting together my garage. This past weekend I purchased 4 of the Kobalt Wall Cabinets from Lowe's. The cabinets went together easy enough. However, I'm struggling with installing the rails that the cabinets sit on.
The instructions say to drill four 8.5 mm or 21/64th holes, (2 into each stud), and to place an expander into each hole. These are rather large holes to drill into a stud that measures roughly 1.5"????? Also, if Iwere to do this, the slots in the 30" rails don't line up with each stud (16" centers).
My question for those of you who have installed these cabinets: Do you think it would be safe to only use two of the supplied screws to hold up each cabinet rail? Or, if I go this route, should I use two lag bolts?
Thanks for your help!!
