Kobalt Wet/Dry Vaccuum Filter #0141369
ezriderga
NW GA
My Lowe's (area code 30165) has these filters marked down from $14.97 to $2.69. On Amazon they are listed for $27.33. I bought one (even though I don't need it, bet none of you do that) but I may go back for more. They had about 12 left on the shelf. Good Luck!
E
ezriderga
NW GA
Probably so. I tried to use one in my Shop-Vac and it wouldn't fit. On the box it reads, "For use with Kobalt Wall-mount wet/dry vacuum." The id is approx 4", the od is approx 5 3/4" and it is 5" tall. I hope this helps.
fivespdcat
Definitely helped. Unfortunately I only have a shop vac. Thanks for the update though!
