I usually just clean the jets w/ copper wire. Of course, check your air filter and other easy stuff before tearing into things....Are these carbs worth cleaning, or is it better to replace?
As other have said, surging is almost ALWYAS caused by a lean condition. Typically the low speed/pilot/idle jet (not the main jets).Surging at light or no load would point me towards plugged jets in the carburetor.
Yes, it is worth cleaning, unless you are willing to buy a genuine OEM replacement. Aftermarket carbs are typically less than 50/50 !Are these carbs worth cleaning, or is it better to replace?
It is almost ALWAYS the pilot jet !... it turned out to be another jet that I never knew existed. It is called the "pilot" jet.
I ended up buying a new jet. It was cheap and the old one was so clogged with hard **** that I was too lazy to mess with it. Even my big ultrasonic cleaner wouldnt touch it.It is almost ALWAYS the pilot jet !
On some carbs is is difficult to located the pilot jet. On smaller engines you might need a micro-drill set (#60-#80) to clear any blockages. Worse, on some Vee engines (Generac), you have to remove the intake manifold and the carb as an assemble.
Check YouTube. There are several videos and cleaning the carb for that engine.
Which is why I saidI ended up buying a new jet. It was cheap and the old one was so clogged with hard **** that I was too lazy to mess with it. Even my big ultrasonic cleaner wouldnt touch it.
A dirty air filter will make it run RICH (and not surge).If it still does it after cleaning the air filter, I might mix up a small amount of gas with a heavy dose of carb/fuelinjector cleaner and run that throught.
