KR657 Ball Bearing slide removal from box?
cplnorton
I picked up a KR657 off craigslist yesterday. I figured out how to remove the drawers no problem. But I can't figure out how to remove the whole ball bearing slide from the box. I want to remove all the slides so I can soak them and clean them.
Thanks so much!
C
cplnorton
I think I figured it out. There is a rivet that when you extend the slide all the way. It looks like you drill it out and then just lift up? Am I thinking right?
zkling
You have to drill out the rivets (2 IIRC), then lift up and it slides forward. It blows, the slides are once piece. Use a sharp bit and do it fast, if the rivet starts to spin, it becomes a real pain.
C
cplnorton
I went out and did them. I used a new bit and still about half spun. It was a pain in the ****.
I think when I put it back together I'm going to use screws. It would make it much easier to tear apart.
Wamsutta
Amarillo, Texas
You don't even need screws. The way those bayonet slides are set up, the weight of the drawer keeps the slides held to the wall.
