Kydex experts here?
toplessHO
central florida
working with a plastic whose name brand is Kydex-V
its there any way to weld this with a plastic welder?
Im using a heat gun to form and that works fine but need to
join the joints.I have tried a little welding and it can be overheated.
liliysdad
It can be welded, but it doesn't typically turn out well due to the extreme sensitivity to heat. I worked Kydex and Bolatron pretty heavily in the day, with holsters, sheaths, etc. I never found a suitable chemical bonding agent. Mechanical bonding through rivets and fasteners was always the best way.
T
toplessHO
central florida
I may try for my application.
I think that I need nitrogen to make the thermal welder work without it looking like burnt bacon
American Locomotive
Rhode Island
The process they described to solvent weld it sounds nearly the same as how PVC pipes are joined. PVC "glue" is actually PVC shavings dissolved in a solvent. PVC joints are ridiculously strong.
It wouldn't surprise me if a Kydex solvent weld wouldn't also be very strong.
Solvent welding is messy, and riveted joints give a certain look and are easy to do, so that's why I suspect most people working with kydex go that route.
T
toplessHO
central florida
Got the THF so tried solvent welding.
Test pieces with solvent about size of a thumbprint,clamped in vise overnight.
I couldnt pull pieces apart. Put one piece in vise and twisted the other until weld broke loose.
It took considerable force to break the bond.
I welded the corners on 2 pieces with the hot air welder and it did OK.
40 grit sanding disc cleaned it up.
The star of show was the combo of shavings,THF,MEK.
With this I was able to paint on a paste that dries to same as parent material.
T
toplessHO
central florida
I did some vise grip clamping on other pieces and did fingernail test on the
dissolved part that squished out.
within a couple hours I removed clamps,but didnt do a destructive test on it.
