Label Maker
LSU
My old label maker has died.
Looking for a replacement.
ideally one that makes larger ones with an easily changeable tape.
Thanks
SILVERPLATE
Fort Worth, Texas
I have a P-Touch that I have owned many years that plugs into my laptop. Makes awesome labels extremely easy, resizing, fonts, etc. Drawback not to portable for a job site but great for home.
  • Like
Reactions: LSU
shawhite
I have both the brothers p touch and an epson label works. The epson does not waste nearly as much label as the brothers but the brothers is easier to use.
  • Like
Reactions: LSU
Sumboodie
AK
I've never figured out why my 2 P Touches (different models) always make the label much longer than it needs to. I almost always end up having to cut it with scissors.
Grant Gunderson
Bellingham, WA
I have owned Ptouch and others but my Brady21plus is hands down the best. You can control exactly how much label it uses each time so you save a fortune in consumables. Plus it can even do heat shrink wire labels.
I have several P Touch, bought used. They do the job. One new one got me hooked, can never find it when I need it, thus the others, which are bigger and harder to lose.
  • Like
Reactions: LSU
PugetDude
Superstition Mountains, AZ
Print all your labels in a string, one space between each. Plenty of room to cut each label from the string after you use the built-in cutter to cut only the LAST label... You'll save a ton of tape. I use a Brother P-touch- details in my project thread.
HenryAZ
MEMBER EMERITUS
South Congress AZ
I had an older P Touch for 30 years before it started jamming tapes. I replaced with the newer model. IIRC, there was a setting somewhere on the older model that allowed you to eliminate the extra tape on the tail end, at least. I haven't looked for that yet on my newer model.
  • Like
Reactions: LSU
American Locomotive
Rhode Island
The Brother P-Touches waste a tremendous amount of tape, especially on smaller labels. It has to do with the mechanism of the tape - it's not just one roll inside the cartridge. There are two different "supply" reels, and a take-up reel as well. It thermally prints the label, then peels off the unused pigment, and then applies a clear sticky layer to laminate it. The labels are super durable. but the design of the cartridge makes it so that at the minimum you need a 1" leader. It's terrible for small labels. It's fine if you're printing a lot of labels in a row.
Dymo has a basic heat-transfer label printer for like $20 that doesn't waste nearly as much tape.
Rinspeed
NY
I have the Dymo LT100 and it works just fine. I use aftermarket labels that are much cheaper and work as good.
  • Like
Reactions: LSU
Sumboodie
AK
Dymo has recently introduced labelmakers that require you to buy only their labels. (the cartridges have DRM in them). That makes any of their products a hard pass for me.
I didn't know that. I usually end up with the off brand labels for the P Touch. They seem to work just as well and are quite a bit cheaper.
  • Like
Reactions: LSU
Sumboodie
AK
I've gotten in those settings and it never seemed to make much different. It doesn't bother me so much that it's wasting label material more than I often need to find scissors and trim it so it'll fit where I'm sticking it (hehehehe).
  • Like
Reactions: LSU
GreyOwl
North Las Vegas
I have an older p-touch and it is only printing part of the lettering. Is there a part that needs replaced or time for a new one? Not at home now so not sure what the model number is.
  • Like
Reactions: LSU
CS454
The fact that NOBODY has pointed out the first rule of the labelmaker in this thread has me worried.
Remember, the first thing you label...
ddawg16
S. California
Label makers are kinda like injet printers,.
The printers are cheap,.....until you have to replace the ink cartages
