ladder/ scaffold question
dshop
I have several aluminum Warner 12' extension ladders. Would these be safe to use as a low scaffold on top of some sawhorses...planked with plywood as a surface?
I am thinking to use this when setting some brackets and some paint work in the shop.
lukedwag
If you took 3 of them and had your horses at 10' oc with some 1/2 inch plywoood you will probably be ok. It's not really what a lader was designed for but would probably be ok.
JRC3
Southwestern OH
I think you mean Werner and I'm guessing 12' as in a unextended 24' ladder, so it's doubled up. I wouldn't worry about it one bit.
NUTTSGT
Northern Central Ohio
Even though ladders are tested by being placed on saw horses and a weight put in the middle of it for a timed test, I wouldn't do it.
On the other hand, I have a nice 2x12 that I use for a plank. Some would probably say not to use that either.
bad_idea
Pasquotank, NC
I suggest getting a couple 2x12s from the lumber yard. If the bounce in the 2x12 bothers you, screw a 2x4 on edge to the underside of the 2x12.
manwithtools
Lebanon, TN
I know I'll get flamed for this, but none the less. While I was a few pounds lighter then, I used that exact solution many times. I weighed around 150 then. I screwed 4 two by fours side by side to the rungs to make a walk surface. Plywood would work just as well. I only used one section of an extension ladder.
benjamintmiller
IA
You could make some nice planks out of 2x4s on edge with plywood covering them. I've used 2x12's before and they have a lot of bounce and really aren't wide enough to stand on.
bad_idea
Pasquotank, NC
I was working off a 2x12x12 ran across a couple ladder jacks this afternoon. Worked just fine. I am TERRIFIED of heights and I felt comfortable on the 2x12.
Iron-Iceberg
A-town
Just go to a local building supply and get a few scaffold planks. That’s what they are for. No knots, good wood and safe for the job.
rharman
SoCal
I trust my scaffold plank from Little Giant but I sure wouldn't trust an extension ladder for a scaffold.
Boilerhouse
Muskoka
I also have the 2 x 12 x 12 plank with two 2 x 4 x 12 side rails to strengthen it. I have used it several times. It is certainly strong enough for me, just not the lightest thing to maneuver around.
