Lam-Beam Removal Y/N?
sthojlft
I have a pretty standard two car garage however it has a two post low profile lift.
Floor to post top ~ 8.5'
I can almost stand up under car.
The house is about 20 years old and it has, I presume, a lam-beam coming off the ceiling down about 6" covered in shtRc.
Are there any less then totally destructive ways to remove the beam and replace it with something else to gain back the 6". .....I could then stand up.
pop pop
Virginia
Probably easier to lower the floor, and I know your're thinking that isn't quite possible!
rslaback
Westcentral Wisconsin
It is removable but not by any means easily. You most likely have overlapping joists on top of that beam. In order to remove it, you would need to put a temp beam on both sides of your existing beam, remove the existing beam, cut all of the joists in the ceiling to length so that they will stop exactly at the beam, nail joist hangers onto the beam at each location, slide the new beam up into place, nail the joist hangers to the joist and then rock the ceiling.
Honestly it is a lot of work for what you would save.
This advice is null and void if the beam is actually supporting anything other than traditional joists (i.e. trusses, TJI etc.).
You probably have this:
You would need to change it to this:
The Boss
Connecticut
I'm going to go with no on that and suggest that he already has the 2nd image and that the beam supporting his second floor is not just a 2x6 member but in fact a 14" tall beam that protrudes below the lower plane of the floor.
If there are no posts in the center of the garage, there's no way his beam is only 5 1/2".
shooting4life
depneding on how big it is you might be able to replace it with a steel I beam and save some space.
sthojlft
Wow, my new hero! Power of www.
Thanks:rocker:
sthojlft
More specifically...
Great pictures but I'm trying to visualize where the rest of the "beam" is.
If the floor joists are resting on the beam would not the beam extend downward from the overlapping joist ends say 12"?
I assume it is a Lam-Beam or other that is probably a 12 x ....
THX
+ what would be the best way the cut off the joist ends "square" with the least profanity.
rslaback
That is possible although my guess would be 2x6 joists and a 11 3/4 LVL beam. Although I can't think why anyone would do option 2 in a garage during a new build. Method 2 is a pita to install compared to option 1 and is usually only used in basements that are to be finished spaces.
sthojlft
Where I live pretty much all "new construction" ...20 years ago or not... is just ****. No level of awful construction would surprise me on my house.
So your saying that the 2 x 6 joists are butted into the lam beam flush at the top and what protrudes at the bottom was covered with sheet rock?
The Boss
Connecticut
Can you provide a picture of the garage layout or possibly give us dimensions & a little more information on layout? Posts/no posts, finished or attic space above?
Otherwise we're really guessing.
jack stand
Lakes Region Maine
I would be suprised of you had a lam beam (LVL) or other "engineered lumber" product in a 20 something year old house. You need to do some "destructive" exploration to see how it's built and to develope a solution. You might start by figuring out the "mechanicals" that may run in the joist "bays" before you start poking holes in the drywall.
sthojlft
Yes...can do.
I'm sitting in living room feeling like **** (food poisoning?). So I started posting.
But pictures....description...no problem. Tomorrow.
Heck I'll even cut a hole.
You've been very helpful.
NUTTSGT
Northern Central Ohio
My parents home was built in '79. It has two laminated beams in it. One in the basement spanning 1/3 of the house and the other in the garage creating a somewhat vaulted ceiling.
The beams are not what we know now as laminated beams but more of an early version. They are basically 2x6s, stacked and glued together. Chances are the OP doesn't have a beam like this but you never know till it's opened up.
MoparCharlie
I second this reply ^^^^^
10 years old yes.....
20 years old doubtful
sthojlft
PICS , PLZ help.
There is no LVL beam. The distance from the upper floor bottom/top of joists to the very booth of sheet rock is ~ 16"... This is a lot.
I assume it is more then one built up beam.
Rundeep_32
I have flush mounted joists on the I beams in my new garage. The joists are hung to the I beam with hangers attached to 2x10s that are thru bolted to either side of the I beam. Works great. Garage is attached to house and is 36x32 with no columns.
rslaback
A picture looking up vertically into the hole would help.
Is your house a modular built house? If it is built like I think it is, that beam most likely isn't going anywhere.
sthojlft
How long is your I beam and what kind of money is it to buy?
I need to measure my garage but I assume its about 20' wide.
What did you set the ends of the beams on?
sthojlft
Steel flitch plates in there? Are there carriage bolts going through it?
I do not think so.
Looks to me like three 2 x 10 then a ripped 2x2 as a hanger and just nails.
I have no idea of what extends below the 2 x 10s ...some kind of 2 x 6...?
sthojlft
I do not think so...
This house was built by an idiot...first house....very little supervision of subs that ripped him off.
..."that beam most likely isn't going anywhere"... What does this mean.?
Rundeep_32
There are 2 I beams in the garage. Each is 32 feet long and supported on each end with concrete filled steel columns that sit inside of the 2x6 exterior walls. The I beams are welded to the top plate of the columns and the bottom of the column is bolted to the footings.
I don’t know the cost as they were part of the overall new construction. Sorry.
rslaback
IN a modular home build, the joists can be screwed through the beam very similar to how it is done on the rim joist. Then when the sections are installed the two center sections get bolted together, forming the beam. If this is how yours was done it isn't really feasible to take it out.
To be honest, we need to know more about that 16" beam before we can make a call on it. That almost cannot be made of one piece to get all that height. It would be incredibly expensive to find a 2x16 that is 20 feet long not to mention impractical.
dlenkewich
Saskatoon, Sk, Canada
From the view looking into the hole it looks to me that the joists are sitting on top of the beam like in the first illustration on page 1, with crush blocking inbetween.
Though, taking a second look it's hard to say. Looks like the joist is notched to sit on top of that 2x2.
scratchedup
Fayetteville, GA
There is a early version of a lam-beam...
The joists are toe nailed in with a 2 x 2 plate nailed on.
Lam beam appears to be 16+" x 4" ???
Garage is 19' 8" wide.
How big of a steel I beam would I need to replace this?
THX
sthojlft
Maybe someone could direct to a spec chart for steel beams. It's got to be pretty simple...normal two story house...20' span...
Thx
sthojlft
He's just bluntly stating you can't cut into it because you'd be compromising it - answering a question no one asked.
Yes, I get it.
Actually, seems like a pretty cool product (I'm shocked)....I just read up on it in the link.
One can cut it but the manufacturer highly discourages it.
Looks like remove and replace would be a HUGE job.
I could at least take the sheet rock off and gain 1/2" and it is pretty.
