laminated strand lumber
vavet
Ashland, VA
Who can tell me about LSL?
I have the opportunity to own about 8 sheets of 4x12 LSL, about 1-1/8" thick for free.
It's heavy. It's an odd size.
My utility trailer needs to be redecked. How does it hold up to constant weather exposure?
I'm thinking I will just cut into 3.5" or 5.5" wide boards and use it in lieu of 2x4 or 2x6 for shop fixtures, shop furniture, etc. If I can use it for the trailer, that will consume a portion of it, but I will still have a bit left.
Provincial
Near Salem, OR
There should be markings on it to indicate the properties. I believe most everything now is made with exterior glue, but using it on the trailer without verifying that is risky.
Due to its nature, LSL has a lot of end-grain exposed, and that can lead to moisture absorption/ Any exterior project needs to be sealed with a protective coating/paint.
If it weren't free, I wouldn't use LSL for an exterior project. Even then I would be leery. The surface layer may not hold up to the beating a trailer deck takes from scrapes and concentrated loads that seem to happen no matter how careful you are. The greater thickness of 2x material would be better for a trailer deck as the deflection of the thinner LSL will be greater for a given load/span.
Think of LSL as a stronger plywood. Because all the layers are laminated/jointed wood, there is no junky spacer material and the whole sheet is fully structural. 1-1/8 thickness is about the same as subfloor decking, so it could make good bench tops, especially if glued into double thickness.
Lelandwelds
Central Texas
Would make an awesome work bench. A builder/artist ran some through a thickness planer. It made the coolest stair treads. Looked like an exotic wood like black palm crossed with Zebra wood. I know he used a stain that penetrated unevenly and then ran it through the planer again.
Like I said, artist.
I would bet it does NOT use a true waterproof glue. Even exterior grade plywood only uses "water resistant" glue.
archtimb
If it is 1-1/8" thick, it is rim joist material, and not the same as LSL structural beams. You may find it is not as strong since it is made to be in compression only. I would not advise use on a trailer.
BukitCase
Oregon
Hard to beat the price... I too would limit it to INDOOR use, but free's free - even if you don't have 12' ceilings, storing it ALL would only use about 10 square feet of floor space (leaned up against a wall) - if all else fails, you could STILL use it as TRADING stock for something that AIN'T free :=) ...Steve
Retroman
Mojave Desert
We use it for forming concrete slabs with a turn down footing. Holds up great can't tell you how long it lasts as our guys always seem to cut it into small pieces then it gets tossed.
The Tool Tyrant
Bonita, Ca. (San Diego)
This is a new one for me...normally LSL is beams and OSB is sheets. I've used 1-1/8" T&G OSB on floors, but in the 'normal' 4'x8' dimensions. I've never seen 4'x12' sheets...those would be really heavy! :Mr.T:
V
vavet
Ashland, VA
They are really heavy....and they’re not truly 4 foot wide, closer to 42inches....and they are no longer 12 foot long. I cut them into approx 6 foot pieces so I could handle them myself...and because my trailer is only 10feet long. I decided I’ll just keep them until I have a need for them, probably for some shop fixture, but not use them on my trailer.
