Jeeper75
Hello everyone. I am fixing a lamp for a friend at work who buys them at garage sales and wants me to fix them. Usually simple enough but not this one. It has a 3 way switch on it and I see 4 wires hooked up. Thought that was odd and pulled the wires off without marking them. I pull the lamp apart and realize it has a small bulb in the base to light it up.
So you would have 1: Base light on only 2: regular top light bulb on 3: both base bulb and regular bulb on.
I hooked them back up to what i though they were. There are 3 screw terminals on the socket. So I hooked a hot from the little bulb and regular bulb up. One wire from the regular bulb to the neutral. And the other wire from the small bulb to the ground. Plugged it in and the base light is on. Turn switch and pop. Whoops. How should I wire this up? Thanks
