bigger is better, on the side of my house, instead of a "gate valve" spiket, I have a 3/4 Brass Ball Valve, that is supplied right into my well supply, only a few feet away. I water a 1 acre garden, about 150 trees, and several hundred animals. I spend hours each day watering. Even when its been raining.
Every 50' section of 3/4 garden hose I add, causes a noticeable drop in volume. By the time your get to 250', its probably half of the original GPM. Ive got a 22gpm well pump, set at 40psi on and 60psi off.
Im thinking of adding a 1hp "lift or assist" pump, when Ive got allot of hose out. I was shopping them this weekend, but need to talk to my well guy before I do it, my pump is brand new and I dont want to incur a warranty claim problem buy "messing" with the program.
On another note, I just bought a...
" Element Contractor/Farm 3/4 in. x 100 ft. Lead Free Hose "
http://www.homedepot.com/h_d1/N-25e...&langId=-1&keyword=element+hose&storeId=10051
Which is an absolute miss-representation of a "farm/contractor" hose. Everything about it is a lie, except it does have nice cast brass ends, otherwise, its kinks like crazy, just pulling it around watering, the warranty excludes farm or commercial use, its not EVEN 3/4" !, I am returning it. My biggest complaint is how restrictive it is. When you get a pump past 20gpm, you can tell real quick if you are using a restrictive hose or not.
Your hose can be providing more restriction, than you may think, this hose I mention is marketed as a 3/4" hose, I put it against my pump, and I can immediately tell that its not a 3/4" hose. Upon visual inspection, in comparison to one of my "Apex" brand 3/4" hose, you can easily see the ID of the Element brand is easily an 1/8" of an inch smaller. If I was not going to return it, Id cut it in half, just so I could measure it, to see if its even smaller than 5/8"s, its that restrictive.
I use the Nelson brand "fire nozzle" style of nozzle on the end of the hose, to keep my pressure/flow loss to a minimum. Thought I would share that for those who have not seen these, they are the bomb, if you have the GPM and PSI to take advantage of them.
I will also mention, if you do a yard hydrant, spend the MONEY and get a Woodford brand hydrant. You want the "Iowa" model. I had a house, with a "off shore" no name hydrant, that was set in concrete inside the horse barn.
The valve at the bottom took a dump and would not turn off, and the morons that set the whole thing up, tee'ed it direct into the well, so you could not turn it off, as long as you wanted water in the house, the yard hydrant leaked massively.
I could not buy parts for it, because it had no name, for months I collected different brand parts for it trying to repair it. I spent way more in time and money than several new hydrants would cost. Ended up having to cut the concrete, bust is out, then on the outside of the barn, had to borrow a backhoe and dig out the old hydrant (dug under the slab in the barn, it was a good time !) because I could not get parts. It was massive undertaking because some cheap ***** saved $50, and that hydrant was only 4 YEARS OLD !!!!
http://www.amazon.com/dp/B000UETG7Y/?tag=atomicindus08-20
