Ok, so my landscape lighting transformer has given up the ghost.
For some reason it just blinks on and then shuts off after a second. Then in about 20 seconds it tries again. Blinks the lights and shuts off.
So the large black spot on the controller board seems to be indicative of an issue.
However, I don't really care as I would like to put it on a simple toggle switch so I can turn it on and off with a switch.
Can I just connect the 120v power directly to the coil and just put a switch on the *********** wire? I am currently researching this to see if it will work or not. I am not sure what the module does other than add a timer and a light sensor to turn on and off the transformer.
Input= 120V ac, 60hz, 2.7a
Output= 12V/14V AC, 300W max
The end goal is to run it off a simple relay that I can control with an Arduino. Currently the Arduino sprinkler system is right next to where I keep the ballast, so it would be super easy to just add another relay and add some code to the Arduino.
Let me know if you think this is going to work. I can just get another one for $30, but I would much rather have it controlled by the Arduino.
[/IMG]
However, I don't really care as I would like to put it on a simple toggle switch so I can turn it on and off with a switch.Can I just connect the 120v power directly to the coil and just put a switch on the *********** wire? I am currently researching this to see if it will work or not. I am not sure what the module does other than add a timer and a light sensor to turn on and off the transformer.
