Laser Level Advice - relevel house
bdelmar2
Back during my largely misspent youth I used to work in construction, mainly remodels and roofing, but a little new construction also.
I finally managed to get my own home, but it needs some work.
Its what they call pier and beam construction, which is a fancy way to say its held up with concrete blocks.
Looks to be a 4" x 4" x 16" base, with an 8" x 8" x 16" solid cinder block standing on end in the center of the base, and the framing rests on these.
House is just a little over 1100sq ft or so, and was built in 1955. Its what they call a 'cracker box' down here in Fl I gather, a basic rectangle with a porch off one end. The porch was later closed in to become a laundry room, and an addition (dining room) off the long side, was added later - around 1984 I think.
Place is in fairly good condition basically, but the previous owners have gone about repairs/upgrades pretty much backwards. Nice new paint, decent fixtures, tile bath, new flooring, etc....
But I've already had to have a section of the roof reshingled due to a bad owner patch job - they turned a 15 minute bucket of tar patch job into a $500 repair pretty much.
I also had to throw down a quick 3/4" subfloor in the converted porch/laundry room before I moved in. It was still the original beaded decking from '55, which was getting a little soft.
I had to do the same thing in the 10x18 shed out back, fairly new shed, but not a strong enough floor to support my tool boxes/tools etc....
So having done the 'emergency' repairs as mentioned above - plus fix the shower faucet which they didn't replace when they redid the bathroom and was leaking behind the wall, I am now moving on to siding/windows/doors, etc....
The front door doesn't open all the way, and there is a noticeable drop in one corner of a bedroom floor, and a high spot in the living room.
Not bad for its age really, and its a fair bet the house has never been leveled since it was new. I am lucky in that the land is high and dry, somewhat rare here in west central Florida - most every other place I've lived in down here has had some kind of water/flooding issue.
In any case, I need to level the house before I move on with other repairs, I have located a couple possibilities for someone to do the work at a reasonable rate, one of which has actually leveled at least one other house in the immediate neighborhood.
I haven't gotten ahold of them to talk price yet, so its still possible I will have to do it myself.
Though like many of us I've gotten older and fatter and there isn't a lot of room under there - 16" - give or take. I would also have to buy more bottle jacks and round up blocking and metal plates and what have you.
Not to mention I'm not fond of spiders and there may be a couple under there - quite likely Brown Recluse which are fairly common here and not something you want to get bit by.
So if its not crazy high, somebody else will be under there, but still I want to know exactly what need to be done ahead of time, and be able to check the work as it goes and after its done.
Given the age of my construction experience I was thinking an assortment of levels and the faithful old string line to map all this out, but when looking around for a new 6' level I was reminded of laser levels.
We never had those back when I did construction and later when they came out I recall they were considered kind of gimmicky. It appears they have come a long way since them and look like they would actually work and be pretty handy.
I decided I wanted one of those plane levels, like the Bosch GLL2-80 dual plane, and its companion receiver for outdoor work - like under the house itself perhaps, and for later when I put down some concrete, and fencing and what not.
Then I checked the price and decided I could get by without a plane laser. The 2-80 is about $400 by the time you add tax, plus $150ish for the receiver, and then you kind of need a tripod, so $700 or better.
Plus one isn't available locally, so I would have to have it shipped, and being a delicate instrument compared to some of the stuff I have had mangled during shipping in the past I'd prefer to avoid that if possible.
Which brings us to the Bosch GCL 2-160 S. Its not a plane laser, but rather a dual line laser. I will have to move it a little more during use, but its available locally at home depot, so I can return it for a replacement if I get a dud, and its $179 plus tax.
I will still have to order the receiver online, but its only $80 ish plus tax.
Its also a lighter laser and I can use the $36 tripod (instead of the $150 one), also available at home depot.
So about $350 or less for the whole setup, laser, receiver, and tripod vs the $700 or more for the dual plane setup.
I figure I can set it up in one corner of a room, get most of that room and move it to another corner and get the rest, plus get reference marks in hallways/other rooms if necessary.
It can also use a receiver in pulse mode I gather, which makes it more useable in bright light/outdoors and also extends the range to 165ft.
I'm not having a great deal of luck finding 'real' reviews of the GCL 2-160 S, or many laser levels at all. Some, but mostly generic stuff I could figure out from the ad copy myself.
So what I would like to ask fellow GJ users is if anyone has any experience with this particular level (GCL 2-160 S) or has a better comparable alternative.
Also if anyone knows of a good home repair/remodel website/forum I would appreciate hearing about that as well. I've found a couple, but none were really targeted toward what I'm looking at, or weren't active enough to bother setting up an account for.
Thanks.
Citation
Indy
Are you open to a very low cost alternative? I've done a few projects where we wanted things level over about 20 feet. This was done with 30' of clear plastic tube for with water. When you fill the center of the tube with water and hold the ends up the water level at either end will be the same. Setup a fixed post that will be your zero point on the floor and attach the tube so the water line is say 2' above the floor. Now move your other end of the tube around the house and measure how high its water line is above the floor.
Note, it's helpful to have two people because as you move the tube the water level will change a bit. With a second person they can raise or lower the tube as needed at the reference point. Alternatively you can just measure the water height at each end and rescind the difference each time you move the tube.
Hilltopmasonry
Water level...we still use them over the fancy laser levels since they are easier to see in the sunshine
Fill them up with windshield washer fluid since it's blue
Citation
Indy
Damn... that seems like an obvious name :D
A web search shows a lot of information for the OP.
bdelmar2
I'm aware of water levels, and have actually used them in the past.
I agree they are a great thing, but somewhat time consuming compared to a laser, and I would have to locate and fill a hose and make a reference board, etc....
With the laser, I point it roughly where I want, turn it on, and know within seconds how far off my floor (or whatever)is, or isn't. Handy to do before paying whoever I hire to level it.
String line with a bubble level would also work, as would a 6' level, but once again, fairly time consuming, and more work involved.
Storage and reuse is also handier, could find some plugs for the clear hose, but in the Fl heat they get pretty stiff in a couple years and are basically useless.
I do thank you for the suggestion though.
texasprd
San Antonio, TX
Pay close attention to the accuracy spec on the laser levels. As they say, you get what you pay for...
Since cost appears to be a consideration, I was going to suggest the water levels, too.
txvwnut
Bedford, Texas
Every house foundation repair company I've seen uses some for of liquid line level for measurement. They set one end in the most middle part of the house or sometimes by the front door then carry the other around to measure the drops in all the rooms compared to the starting spot. A laser line level will not let do you that so you will be leveling off what ever plane its on every time you move it to a new spot to check. You'd have to make sure all of the area you set the laser level at are on the same plane to get a close to accurate setup to level the whole house.
Since this appears to be your first time with a pier and beam house I will tell you that they tend to move around a little between seasons. If you house has a solid foundation wall around the perimeter then you will need to either have a professional company do it or get ready to dig a lot of deep holes to set your leveling blocks and jacks in.
CTyankee
CT
I'd use a reservoir water level too...Some folks only think of the two hose end method.
Make one of these. There are other instructions available on Youtube.
https://www.buildeazy.com/waterlevel.php
This explains how it works and how to use it..
http://www.factsfacts.com/MyHomeRepair/WaterLevel.htm
It works around corners and out of site lines. Many times I've reached for it over a laser.
Set your reference marks all at once and measure off of them for your elevation.
Leaflessshadetree
Don't ask.
I don't think that laser level will work outdoors. It's often impossible to use a laser level to get opposite sides or corners of a house anyway.
Liquid level is the right tool for the job.
My Old Tools
Hamrick Lake, TX
I have had a few houses leveled. The first one 25 years ago used a spinning laser. It just spun a laser in a circle under the house. Use a tape measure to measure down from the rim joist and see where it hit every few feet. When they all match you're done.
http://www.johnsonlevel.com/C/17/RotaryLaserLevels
When I had my slab resurveyed recently, they used a GPS based instrument. Just set it on the floor inside to get a reading, then move it and read again. It could map the whole place in a few minutes.
For spiders and bugs, get a couple of cheap "bug bombs" at HD. Remove any edibles that are not tightly wrapped. Throw 3 or 4 under the house.and sleep somewhere else that night.
When leveling a structure, you need to determine if the joist has sagged/bowed or if the pier has sunk or possibly both. Screw jacks work if you have a long enough lever.
