laser receiver for a Bosch GLL 2-45
billconner
Thousand Islands NYS
I bought the level for kitchens and trim, but now working outside. Was curious if anyone had recommendations for a receiver that would make this work. On line manual says Bosch LR 30, but maybe others, even non-Bosch, would work and cost less.
Thank you!
danski0224
Near Naperville, IL
As long as you match laser detector color to the emitter color, any of them should work.
The only way to be sure is to find the wavelength spec for the emitter and then match the detector. I don't know if any of the consumer manufacturers are using funky lasers to tie the buyer to a specific detector.
And of course, the emitter needs to have a pulse function. Some of the newer line lasers are pulse by default.
tarbellb
Oregon
There are pulse detectors and line detectors, be sure to find out which you need.
Color is the other factor, after that, you should be fine.
My Hilti 3 plane pulse works just fine with my (cheap) Huepar detector
