I am adapting Nissan 300zx polyurethane subframe bushings for use on my 1982 280zx. The primary modification is to turn down the outside of the bushing to fit the smaller diameter of the 280zx's subframe. My question is related to the sleeve that goes inside the bushing. The ID of the 300zx kit sleeve is 0.861". The ID of the stock sleeve is 0.836". The OD of the bolt is 0.794". I'm trying to decide if I should make a new sleeve on my lathe with a tighter ID to fit the bolt better - what do you think? If I do, is aluminum OK or should I make it out of steel? I don't know if my machine has enough gumption to cut stainless.
Here is the guide I'm following:
http://www.zdriver.com/forums/280zx...1/polyurethane-subframe-bushings-maybe-19834/
Here is a pic of the subframe bolt on the 280zx (top). Note the funky shape. Any ideas why its shaped like this?
Thanks!
Thanks!
