bad_idea
I recently had a Grizzly 12x37 lathe follow me home. The price was right, free! It came with a 3 jaw chuck, a 4 jaw chuck, faceplate, rocker tool post, a follow rest, steady rest, Dorian quick change tool post (SD30BXA), and tail stock. It also appears to have an attachment on the backside of the carriage that I think is for cutting tapers?
I would like to make a pair of alignment pins for lining up flanges. They need to be around 5/8" diameter, approx 3" long, a head on one end and a decent taper on the other end. I have some scrap material I can use for turning. I just don't know what tooling I need to accomplish this task. I am under the assumption this is a simple task, a good beginner job for me to 'cut my teeth' on. Am I missing something? I am not sure what tooling I need though. Cost is a definite factor at this point in time. This is strictly for home use, so top dollar equipment isn't necessary.
I think I need a set of cutting bits, I saw this set on ebay, will they work for me? Is there a better set I should be looking at for a reasonable price? I don't think I need a center to support the end of the workpiece because the part I am machining is only 3" long, do I need a center for that? What else do I need for this? I would eventually like to use the Dorian quick change holder, but it doesn't have the bit holders, only the tool post. It looks like the only benefit of the quick change post over the rocker post is speed and perhaps adjust-ability. Am I missing something there? Will the rocker post accomplish this task and later the same bits work with the quick change post? I have a set of calipers, a dial indicator, and a 0-1 micrometer. I occasionally do alignments at work lining up pumps and motors, so I have a bit of experience/knowledge/tooling for that.
I am sorry to ask so many questions. Machining is very foreign to me. Thanks for the help everybody.
