I had a bit of a Kubota addiction
Where did you find a Kubota walk behind? I have never seen one. Do they still make them? I want one!!!! It seems all my tools are turning orange.
I have the Cub Cadet, with casters, from 2010. It isn't what the preceding model was, but it has held up well, considering it is the one piece of equipment I neglect. This spring, I had to "fix it". There was a spring wire that came loose from the auto-choke system.
What I like:
-Casters-Awesome!!!!!!!!
-Rear wheel drive
-A tank of fuel lasts a long time
-Strong, tough motor (I did the first oil change, last year, after five years of mowing. Still on the same air filter, just sprayed out, with air, a few times. Still on original spark plug). This was one of their first "in-house" motors.
What I don't like:
-Plastic on the rear side of the deck, flexed enough to get hit by the blade, shortly after buying, that the bottom broke out. Stupid design.
-The tab that holds the rear height adjustment broke, after a few years.
-The drive belt, around the blade shaft, which drives the rear wheels, comes off, randomly, no matter how tight I get the cable. My friend's Husqvarna has a tab to stop the belt from coming off the pulley.
-Supposed to be variable speed, it's stop or go.
