Lawn mower for 1 acre lot
NUTTSGT
Northern Central Ohio
I have an acre lot. It has some hilly areas, a patio to navigate as well as some landscaping to mow around. About two months ago, I bought a John Deere S130. Admittedly, for a very long time, I have had a service cut my grass so my experience with mowers may be dated, but I absolutely love the S130. The V-twin has plenty of power, very little vibration, hydrostatic transmission is crisp, electric PTO engages well and the electronic gas gauge is very handy. Great to have cruise control as well. I leveled the deck after Lowes delivered it and the cut is very even.
The two things I did not care about were easily fixable: (i) You have to keep a button pressed to be able to mow in reverse. I fixed that by shortening the two wires that go into that switch; (ii) It takes a special oil filter that has oil in it; they call it 30 second oil change. It does not change all the oil. Easily fixable by replacing that setup with JD parts for under $40. That makes it take a regular oil filter and drain.
I have a 40-inch spike aerator as well and I don't think this will have any trouble pulling it.
I would recommend the S130. The turning radius is perfectly fine around all my landscaping, patios etc.
If that is like any other JD product, You hit the button once as you reverse, as long as you keep backing/reversing, you don't have to keep depressing the switch.
laser3kw
northen IL
Any comments for John Deere S130 and Bad Boy MZ rambler 42"
John Deere has fallen out of favor around here in the last 10 years (farm and residential). Bang for the buck just isn't there and maintenance cost are horrendous.
Renegade1LI
long island ny
I have a jd160 and a z530r at two different properties. The 160 will cut about 1 acer in 45 minutes, about 20 minutes with the zt. The other difference is the cut quality, the zt gives a much nicer cut and can cut taller grass with no issues. I think you would do well with even the cheapest zt from hd or lowes, they will still out perform a garden tractor.
P0234
NoVA
LOL at the I mow an acre with a push mower in an hour. To do that you have to be mowing at about a 10 minute/mile walking pace. That's a fast enough pace that most adults can't do without a mower.
cherokee
Kansas City MO
Any comments for John Deere S130 and Bad Boy MZ rambler 42" ?
What I would suggest is set your max size as the area you need to squeeze through. Between two trees for example, or get through the gate in a fence, that should be your max width.
Then work down from there according to your other needs. You don't want to take up too much space, but 42" is a bit small, I think 48 would be the lowest I would want to go if I could get it everywhere.
If you don't need it for anything else a zero turn is going to be faster no question about it. You MIGHT pull a small garden cart with it but that will be about it, not really made for much more. I pull a good sized cart with my 42" simplicity.
Currently I mow roughly 13ac, and I mow 13 because I don't want to mow 14. When gas went sky high a few years ago I just did around the house, and the little zero turn was great and fast.
cherokee
Kansas City MO
I can not think of anything worse, I mow a bit more, but walking behind a mower yesterday would have been a real drag, 90F, and 93% humidity. At least on a rider the grass is "down there" so it will not be stuck all over me, and I have a place to set my drink.
Crabman
Alexandria, VA/Dameron, MD
The OP does not say whether he is able to maintain/repair what he buys. Lawn tractors are not terribly complex pieces of equipment. Buying a good used unit can save a lot of money as has been pointed out. And the weaknesses of the older tractors are generally known so you can look for them or work around them.
I have had older Deere HD type units, L120 and L130, made about 20 years ago. 48 inch deck (surprisingly faster than 42). L120 had 20 hp twin cylinder Briggs, L130 has 23hp Kohler Command, The weaknesses are known: the front wheels have bushings, not bearings, solution is to install a bearing kit; the wheels come out of alignment and the steering arms are not adjustable, solution install adjustable arms. Deere dumbed these items down to reach a price point at HD or Lowes. The big weakness is the ******, a K46 I think. The tractors are not really made for hills or much towing. I have been conscious of this and will tow a cart full of mulch bags, etc. but I do not tow heavy stuff, and I have used the tractors on fairly flat lawns.
The one I am mowing with now (L130) I bought for $500. Guy was original owner over on the Eastern Shore, and his yard was really flat so I figured the ****** was ok. I solved the bearings and the steering arms and also the pto switch. So I have $7-800 in it and it has been mowing great for 5 years and has about 550 hours. It runs great, the Kohler is strong.
But like anything else you need to change oil and filter, air filter, etc. I also keep a trickle charger on it in the winter, which has really helped battery life.
If the OP is at the stage of life where he does not have time to fool with it, new is a good idea, and it should last a long time. A lot of premature failure issues look to me like poor PM. You are not going to pile up the hours mowing an acre.
I am also probably in the camp that a ZT is overkill for one acre flat lawn. But if saving some minutes every time he cuts adds value I can see that too. A tractor with a cart/trailer is very handy. I am getting old enough that I am not a fan of my wheel barrow any more...
In any event best of luck to the OP finding the right fit.
jives
Central NY
I love this debate everytime it comes up here and on other discussion boards. There is so much missing, including what other tasks, one's aversion to mowing, type of yard/grass/obstacles. As a point of reference I have varied mowing requirements, from dodging trees to "brush-hogging" 4 ac, to a nice 1 ac flat parcel. I have mowed regularly with a 48" Wheel Horse tractor, a 60" Simplicity Sunstar, and my current 60" Snapper Pro (Hydrogear ZT3400 transaxles, a Ferris rebadge). I've mowed with my buddy's massive Gravely Pro with ZT5400 hydro units, and for a while I mowed my other friend's yard with his Ariens 54" Ikon.
Does the ZT save time? Yes, mostly in that I can hit the long straights at 8 mph. Is the ZT better in corners and around obstacles? Yes, but not as much as everyone thinks. In order to prevent the grass smushing from the inside wheel the turns need to be super careful. I could mow around trees almost as fast with my tractors, and never ripped up the grass. What is also missing from this conversation is the grass/soil composition and dampness. My clay soil is most always damp and there is very little I can do but go really slow to prevent grass smearing. In the dry late summer, things are different. Those of you in the dry areas or with different soils have little idea. Wetness and soil also play a role in getting stuck, for which ZTs are infamous. The caster wheels easily make or find ruts and you cannot turn them out of the rut. Not so with regular steering. The commercial ZTs are huge, unnecessarily wide at the rear tires, and weigh a ton.
Unquestionably the Sunstar was the best mower, best lawn care implement, best at everything. Seriously heavy duty STAMPED deck, massive hydro unit, driveshaft for the mower deck, "easy" to remove deck (well, for about 200 lbs or so), easy to service, two speed ******, differential lock, and comfortable one arm steering and throttle control. I only got rid of mine because at 30 years old it finally starting nickle and diming me.
PoorUB
Fargo, ND
"No way in hell I would push mow if I had cash to buy a mower. "
Purchased a tractor just last year after push mowing a 1/2 acre for years. If the tractor died tomorrow, I would have another ordered by the end of the day. Never will I ever push mow an entire lawn again, never.
I mentioned mowing my dad's 3/4 acre with a push mower. I begged and pleaded with him to buy a rider and he would tell me we didn't need one. I moved out and in a couple weeks he bought a rider!
I guess he didn't need a rider because he had me!
When I came home and saw the rider I mentioned his comments that we didn't need a rider! He didn't have much to say!
cherokee
Kansas City MO
I called my son an O.L.S.D.
Organic
Labor
Saving
Device
He hated that.
cherokee
Kansas City MO
You are right, usually they don't go into much detail, it would be nice if I could do........
The thing with a zero turn it is a one trick pony, sure it could pull a cart, but that is it. If you have any other needs you need to look elsewhere.
This is currently what I mow with, before this "we" used a ford 8n with a 5' finish mower, a 54" craftsman and a 42" simplicity zero turn. It would take the three of us a good two days to mow everything. With the below machine the two of us, wife and I can finish in roughly 4 hours. Not kidding.
bb29510
got a 1/2 acre, and the guy next door works off shore so he bought a high dollar zero turn, when ever he home, he cut his, mine couple others on the street and then ride up to the church and cementary. he just likes to ride
scooby074
Nova Scotia
My neighbour down the road just got one of those Robot Mowers. I think his is a Husquvarna. The thing keeps his approx 1ac lawn neat and tidy. Any time I go by, its out there just doing its own thing.
If I only had one acre at a single location Its what Id be going with for sure.
Kaizen
New England
zero turn is for small lots imo. go with used john deere/home depot ones all day long or comparable from people moving. 42| decks. trash when done. buying new at this time is ridiculous. My scotts john deer is from 2001 and damn if i say that thing starts every spring. Been waiting for ten years for the engine or trans to blow so i can get a pretty one but nope.
Jazz1
Thunder Bay On.
Dont mow the lawn is also a option
One house in our neighbourhood put a "bee sanctuary" sign in front of house,,,he sits on a acre. Didn't cut the lawn last summer... looked fine to me with all the naturally occurring wildflowers and clover.
jonesg
northern Maine/
"ONLY" 9.9% interest, they claim that as if its a great deal.
At a certain point it might be better to just get some goats.
P0234
NoVA
Send us pictures after your bee sanctuary has started.
bwringer
Indianapolis
You guys sound like your typical 14 year-old when he is ordered by Dad to go out and mow. Scalp it at mach 5 so you can go back inside and play video games.
I'm still that 14 year old, I guess. Grass farming is the single most destructive, boring, and useless thing I can think of to waste one's time and treasure on. My only goal is to get it over with ASAP so I don't get nasty letters from the county, and I can go do something more interesting and useful.
Yup. Hardly any info from the OP, lots of wild assumptions from the GJ peanut gallery. And massive overkill, lots of that. Obviously the OP's only option is to haunt estate sales for a few years and buy and restore a John Deere diesel tractor with a bush hog and a loader... It's just what we do here.
On a serious note, there's a big difference between a one acre lot and one acre of grass. What with a house, outbuildings, driveways, gardens, garden gnomes, trees, etc. the actual area to be mowed and the configuration make a big difference.
I used to know a lady who put so many birdbaths, planters, trees, gnomes, gazing balls, random antiques, concrete sculptures, pathways, stepping stones, etc. in random spots in her yard that it was impossible to actually mow most of it, even with a small push mower. She refused to leave enough space between random ****. You had to just get in there with a big weed whacker and do your best. Most lawn services took one look and noped out.
Nice, very nice! I pay as little attention to grass farming as I can, and I honestly didn't know these things were on the market yet.
Rusty Wrench
Also have a 1 acre lot in NE Ohio. A little less than half (20,000 sq ft) is lawn. Wife mows with a self propelled push. She is 68 now and been doing it for 30 years thru 2 mowers. Takes about 45 min for back and 30min for front.
We see folks around here on 10k sf lots, less than a third of it lawn, using riding mowers. If you're in decent health I gotta advocate for push.
bb29510
my home depot regular mower, I bought in 2002. cheapy, never cleaned it, just mow and fill with gas. about ten years later after a winter with yes grass on the deck for years, the deck fell apart. thank god i can weld, I made a new deck out of 1/8 plate, but still, it hasnt move in three years due to my neighbor. my battery been dead for 15 years, i start it with a hole hawg and a socket of the flywheel
KEH
What ever kind of mower someone gets, it will cut better with sharp blades. That's my next project.
KEH
RickyPetite
Buck's County, PA
Mow 1 1/2 acres. Have a Ferris 1500Z 48" and a 20-year-old JD LX255 42". I ride the Ferris and my wife the JD. Takes us under 1 hour. As others have mentioned, if all you do is mow, the ZTR wins hands down. Fast, maneuverable (I cut the apple orchard, my wife refuses on the JD). I happen to do more than cut, however. Fertilize, tow an aerator, and occasional lawn cart. For this the JD is king. Push comes to shove, I would keep the yard tractor because it does so many things that the ZTR cannot. BTW, I once cut the lawn with a Honda self-propelled and it took me hours and hours...never again.
Mikeske
Washington State
I have a John Deere 2305 with a 62” mower deck and a X-590 with a 54” deck. I mow about 4.25 acres of my 5 acre property. It is 95% open. I have a tried a zero turn and after the third mow sent it back as it actually was not any faster for me to mow the entire yard plus I was beat up the lack of a good suspension seat. The other issue I had was I never could have one hand free. The entire thing some places a good zero turn is fine and others the operator can not stand then. It is all up to the operator
Bolson32
Lake Elmo, MN
I have the cheapest Gravely ZT I could buy for my 1.5 acre lot. It's more than capable.
That said, I'll probably sell it next year and get a Husqvarna automower with EPOS. I think I'd like my time back. Would rather spend that time fertilizing, trimming, to etc.
finn
The UP, God's country
I more or less retired the rider and bought a used flail mower for the 40 hp Compact tractorm a Kioti ck 4010 se hst cab tractor.
It’s probably overkill for a couple of acres, but I don’t have to spend time picking up tree limbs, and I can gradually work on cleaning up the rough edges of the maimed portion of the lot.
it has the cup style cutters now, but I will eventually go to the Y style cutters as the lawn becomes tamed. It’s not a finish mower, but it’s better than a rotary cutter, aka Bush Hog.
Nice sitting in the air conditioned cab , above the dust. Don’t even need a shower when I am done.
p00p
42.4974° N, 82.8964° W
That size is just enough to hire it out or find a budget rider imo.
Pushing would **** if you let it get too tall often, & would require a few refills during the job. I don't recall a pusher to have a gallon sized tank.
