Lawn tractor question..husqvarna
hiccup
W.Ky
Posting in here cause I didn't see a category for this .."tools" maybe
Anyways I have a Husqvarna yth2448t riding mower..While running the engine during some leaky crankcase inspection I noticed hot exhaust coming from around the pipes so I thought maybe I had some leaky flange gaskets..Before I got new gaskets I decided to take the muffler off and just see how bad they were..When I took the muffler loose the whole thing fell away from the pipes..I thought maybe the welds broke but there is no welds..My gaskets look good so my leaking is coming from where the pipes insert into the muffler..So my question is how did the factory seal these junctions?..Whatever was there is no longer present.. Looked them up and it shows them as separate parts too
Mikeske
Washington State
I hate to say this but that is common on the Briggs and Stratton engines. I have seen this type of muffler setup on several different brand of mowers. I know it does not do anything to simply replace the parts as it will leak exhaust again at the same place. Since it is a loud no matter what you do I just put the old parts back together and ignore It. I know my John Deere X590 has a similar exhaust but I never looked to see if it leaked there as there really is not much of a muffler on those lawn tractors can actually do
H
hiccup
W.Ky
Well ok..I'd weld it if I thought I could do it without blowing holes ..Im sure its too thin..***** cause thats a lot of heat to the carb and intake
H
hiccup
W.Ky
got a mig welder? just do tacks on top of tacks etc... and don't try to run a bead .
Yes I do a Hobart..great beads with the thick steel but I **** out at the thin..starting to think I need .025 wire
