Layout Advice
shooon
Dawson Creek, BC
Picked up 12x 2 bulb T8 fixtures and am retrofitting with 4000k LED tubes.
was originally going to install 6x fixtures per side of shop, but the steel beam I have isn't centered and kind of splits things up a bit- I wanted decent lighting on both sides of the beam since I'll be rigging up a chainfall. I picked up an additional 3x fixtures to add to the setup if needed.
So I have listed what I have installed already and was tossing around a few ideas on how to finish the front half of the garage closest to the doors. I'm thinking I don't want to have the light directly above the door track because it may cast a shadow.. anyways here's a few options I came up with.
Work bench and majority of mechanical work will be done at the back end of the shop opposite the wall with the heater.
Thoughts?
