LB to Raintight hub
PoorOwner
CA
I am trying to connect a LB to a panel with raintight hub on top (I will order when I know it is possible)
https://www.homedepot.com/p/GE-3-4-in-Raintight-Hub-TC75P/100195385
Can you let me know if this is the correct fitting?
https://www.homedepot.com/p/3-4-in-Rigid-Conduit-******-64307/100150142
It’s actually indoors so not worry about water, with EMT leading up to the LB
But how do you grab this and tighten it without marring the threads?
kaffine
Henderson, NV
One way would be to assemble the LB, ****** and hub before you attach the hub to the panel. Although it may not line up when tight the way you need. My guess is you would have to assemble it before mounting the hub to the panel anyways as you wont have room to spin the LB around to thread it on.
The other option would be to use conduit lock nuts, the lock nuts are put on the ****** first then get tightened up against the fittings to lock it in place. The allows for the LB to be positioned at any angle needed.
https://www.homedepot.com/p/3-4-in-Rigid-Conduit-Locknuts-4-Pack-26197/100111071
The also make longer ******* if you don't need close that you can get pliers on
https://www.homedepot.com/p/3-4-in-...C-_-NavPLPHorizontal1_rr-_-NA-_-100174792-_-N
https://www.homedepot.com/p/3-4-in-x-2-in-Rigid-Conduit-******-64327/100174792?MERCH=REC-_-NavPLPHorizontal1_rr-_-NA-_-100174792-_-N
P
PoorOwner
CA
You are right, I think i need to assemble the LB to the hub before putting it on. I will just twist them against each together tight and until the hub flange line up with the panel
walrus
Maine
if its indoors why the raintight hub? The ****** and 2 lock nuts will do the trick. Or a chase ******
P
PoorOwner
CA
The top of the panel you can either use the supplied cover cap or order the hub in order to give it some threads, it's just a flange with 4 screws
