I have a portable AC that works fine in the house but not in the garage.
AC unit has an LCDI and GFCI built into the plug. When I plug it into any plug with a GFCI, after a few minutes (usually when the compressor kicks in) it pops the GFCI on the outlet (just the outlet. The wine on the plug doesn’t pop). If I plug it into a non-GFCI circuit it runs fine. I replaced the power cord and it still does it. I had two dedicated 20 amp outlets installed in the garage just for high draw items like this. After the outlets were installed it started popping the GFCI, so the electrician replaced the plug (thinking maybe a weak one) and it worked fine for the rest of the year and into winter. Started it up again with the warmer weather and it resumed its bad behavior.
So why don’t LCDI’s and GFCI’s not get along?
This has happened with two identical AC units. I’ve ordered a third one from a different manufacturer to see if it continues.
And of course the manufacturer (Midea) is no help.
I appreciate any ideas folks!
