Leak in air compressor pump
TKM51
Peterborough Ontario
In one of my wiser moments I decide to change the oil in my compressor . Unfortunately I am unable to seal the pump to hold oil from seeping from the drain plug . I have tried plumbers tape and plumber’s blue goop can’t remember the name . Is there stuff I can use that will hold the seal under pressure .
terry
chinboys
Might the oil drain plug be missing a copper gasket washer or a o ring?
mm08822
Are you referring to a clear site glass type of plug or just a simple threaded plug?
Pic?
