Leaking Air Compressor Sight Glass
Waffle House
Charleston, SC
The sight glass on my air compressor has started leaking from between the metal housing and plastic window. The part number (032-0072) is hard to find. Anyone know whether this would fit?
https://www.amazon.com/dp/B00880DXQC/?tag=atomicindus08-20
I'd like to order from Amazon so I'd get it in a few days earlier than the other seller who's across the country from here. Just don't know if it fits! My compressor is a Kobalt LLA1683066 / 221495 if it helps any. The sooner the part gets here the sooner I can get to work installing hardwood flooring... and get a certain someone off my back about it!
Snaparxon
Nogero Tsae
If it is the same thread size it should work, if it is 1/2" pt you could just use a 1/2" pt plug to plug the hole so you can use your compressor while you wait for the new part.
engnerdan
Minnesota
If it's just a pipe thread sight glass you can get them from McMaster.com, fairly quickly.
Sent from my SAMSUNG-SM-G891A using Tapatalk
