D45
I went to get some cleaning supplies and noticed water in the cabinet, under the sink
There was a steady drip coming from the cold water supply valve........no packing nut to tighten
It was not leaking at the handle and was not leaking at the backside compression nut area
It was leaking from the top 3/8" step which the flexible line it connected to...............so I bought and installed and new line. Still leaking........and actually leaking worse
So, I shut out the main water valve in the basement and installed and new 1/4 turn valve under the sink and connected the flex line. Bone dry, no leaks.
I have never seen a water valve fail in this manner at the 3/8" threaded stem area........what failed and why?
No cracks and the threads all looked good.
