helterskelter
- Joined
- Mar 26, 2010
- Messages
- 296
I have a leaking pex pipe at water meter on the house side. It has several pin hole leaks very close to the threaded fitting that connects to the water meter. I've never worked with pex before and would like some suggestions on the appropriate way to repair and which splices & tools to buy.
To me it looks like an ideal spot for a shark bite push type connector but the reviews I'm reading are hit or miss. Is there a preferred push type connector?
Or does it make more sense to dig it back another ~1 foot and splice in a new piece of pipe with the crimp style splices? If so which cutter and crimp tool should I buy?
I should have measured it but does anyone know what type of fitting the threaded connector is? Or what type I should replace it with?
Lastly how much do you think a plumber would charge to do this repair? If it's only a couple hours it might just be easier to pay someone than mess with it (coming off knee surgery so while I can do it myself I'm not looking forward to it). Thanks for any replies.
