lean-to?
rich1956
i have a 24x65' wood stud,metal covered shop,im going to look into putting a leanto on the side of approx,20-25 x 40' long.what way should i go?wood stud?polebarn style?metal prefab?....rich
Lu47Dan
N/W Pa.
One missing measurement, how tall is your wall you intend on adding the leanto to? and what is the pitch of your existing roof ? Do you intend to follow the existing roof or will the pitch have to change ? Dan
R
rich1956
dan the sidewall is 12'.....dont know pitch i can guess and say that the high point of roof is like 4-5' more more
fefarms
It sounds like you propose a lean-to nearly as wide as the original structure. It seems to me this is going to look way out of proportion, as well as presenting some potential design and structural issues.
It sounds like the current roof is a 4:12 pitch with 12 foot side walls. Add a 24 foot wide lean-to to this, and the lean-to roof is going to start at 12 feet and end up at 4 feet, assuming you keep the same roof pitch as the main structure. You'd have to use a flattish pitch of 2 in 12 to have decent headroom throughout the lean-to, and this raises questions about roof leaks and snow loads typical of such flat roofs.
A 24 foot wide lean-to will double the loading on the side wall, assuming you scab the lean-to onto the existing building. Is the existing wall structure and foundation sufficient to support twice as much roof and roof loading? Or do you plan to add a separate foundation for the lean to? If the latter, how do you do this without disturbing the support for the existing building?
I've seen big, flat-roof lean-to additions on small barns before, and in my experience they look awkward and perform poorly. I think you'd do better to scale back the size of the lean-to or build a whole new structure.
R
rich1956
thanks FE very good points....thats why im asking:beer: ...
rodnok1
NC
24 foot clear span would be difficult(prob impossible), without a truss system. which would leave your head room 4' like has been said. Alot of pole type buildings have @12' lean-to's on either side, usually they are less pitch than main building, so figure maybe 3:12, leaving about 9 foot on side walls. Depending on what type on roofing material you use would determine rafter sizing. Myself I would put additional posts in along the building size and tie it into the building also. Around here lean-to's are subject to uplifting due to hurricanes, so make sure the roof structure is attached to posts well.
