Learning how to weld
Lucid Moments
Gainesville, Ga
So I have acquired a MIG machine and want to learn how to use it. It is a Lincoln 140.
Can someone direct me to a good online source for beginners videos? I have seen a lot of stuff on Youtube but most of it assumes a degree of knowledge that I don't have yet so I am looking for very basic stuff.
cspcrx
Phoenix, AZ
When I got my new MiG I watched a lot of videos on you tube on the welding tips and trick channel. He has a very basic MiG multipart series that helped me greatly.
After that I went to my local welding supply store that actually offers one on one classes. They had me bring my machine in and I took a 2 hour class with them. Best money and time spent. Helped me understand my machine and set it up.
Hope this helps.
L
Lucid Moments
Gainesville, Ga
Hope this helps.
Just watched the first episode and that looks excellent. I need to go and buy some supplies before I keep watching, but this looks like a really good start.
dogdog
use smaller wires... easier to melt on smaller welders... my sp135 perform horrible on .035 but decent on .030...
as far as videos .... this is the best but you might have to pay if your google foo is no good
"steve bleile mig welding"
bdbecker
Iowa
When I got my new MiG I watched a lot of videos on you tube on the welding tips and trick channel. He has a very basic MiG multipart series that helped me greatly...
+1... That MIG welding basics series is a must watch.
It may also be worth looking to see if there are any continuing education classes available at your local community college. Going through a formal course with an instructor giving you feedback can really help with the learning curve and get you up to speed much more quickly than if you were just trying to learn on your own.
matt_i
I would try to wrangle up some 1/8" thick steel x whatever you can find steel to practice running your beads on.
Just flow out the bead in a straight line trying to be consistent. Run beads parallel and then flip over.
See what happens when you go slower or faster. See what happens when you weave the arc...very slightly....little "C" shape as you go or draw little circles in the direction of travel. Change the arc voltage and then the wire speed.
A consistent bacon frying sound is what my instructor urged as a sign of the proper stickout. Slow the feed to minimize spatter but keep smoothness.
When things start looking good try a **** joint and then a fillet (setup a "T" shape so you can practice on both sides.
On the cooled joints you can cut thru the welded area (cross-section, cut perpendicular plane relative to the direction of travel) with a bandsaw or cutoff disk and view the penetration. Then try back-beveling the leg of the "T" down to a sharp beveled edge from both sides (make the metal look like a "V" in cross section like a lawnmower blade more or less) and then weld it, and cut it to see the difference.
Try drilling some small 1/8" holes in the steel and welding them shut. Now drill a 1/2" hole in the steel and weld it shut.
There are more exercises for sure but practicing those skills will get you ready for a lot of different jobs.
