Learning to machine by Tubalcain
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Quite a few people on here have looked at Tubalcain's videos when it comes to machining, but you never see who Tubalcain is. I ran across this video on Youtube of Tubalcain showing what his shop looks like, and it also shows Tubalcain himself. I thought some might be interested in seeing the man behind the videos.
iajonesy
Iowa
Is he located in Illinois ? I really enjoy his videos and always get a kick out of his down-home style of explaining things. He would be fun to spend a little time with during one of his project builds. That's a lot of stuff packed into a small area. I'd love to be around when all that equipment goes on the auction block.
Mike
larry4406
Northern Virginia
His videos are excellent. The shop teacher I wish I had and the one our kids need today. Wait - schools need to have shop first these days.
bczygan
DETROIT! Arsenal of Scrappers
It's amazing how small his shop is and how crammed full of stuff.
I would call it semi-organized hoarding.
Certainly not eye pleasing like some garages here.
But functional. He gives me hope for my small space.
Bill
I've got to add though, he has too much stuff.
Machines he seldom or never uses, tons of fasteners he will never use, multiples of tooling, multiples of machines.
It could be a nicer more pleasant workspace if his fastener and hardware storage was elsewhere, and just the needed tooling was at just the needed tools.
lilredex
Toronto
Good one! He has most things under control with all those metal boxes and drawers. You can tell he has cleaned out a few stores and shops.
Think of all those discarded washers and dryers you passed by, they could be made into some of those storage boxes he shows toward the end of his video.
How often have you heard somebody say "you don't look the way you sound"? Think this guy actually does....he looks and sounds a lot like a shop teacher I had many years back.
jeepinerdeep
South Central PA
This would probably be a question for guys like Kevin....
I have been getting interested in machining, and watching some videos. Tubalcain included for sure. I get a little sleepy though.
But I found this guy, Toms Techniques https://www.youtube.com/user/Figbash3, and to me, he REALLY reminds me of a shop teacher. I guess he was at one point. Is he setting a good example for me? I find him very easy to understand, so I'm hoping yes is the answer ! :)
I don't know squat yet, don't own any machines and would be starting from zero.
speed bump
Butte Montana
Pretty cool to see someone like that show off his shop that took years of work to build. Not having looked at any of the other videos to see what sort of work he does I would love to watch his design process and then workflow throughout the shop.
Bill
I'm going to disagree, having multiples of tooling and machines right there is awesome. Say you are building a bunch of parts. Setup step 1-3 bridgeport, setup 4-5 on drill press 1, setup 6 on lathe 1, setup 7-10 on second drill press. Having enough machinery and tooling to do that kind of stuff makes work a joy.
Moving your hardware storage further away just encourages you to grab extras when you go and not put them back. Then you have a bunch of spare fasteners cluttering up your work bench.
galute
Bald Knob AR
I'm pretty sure I saw in one of his videos that he still teaches part time. Pretty cool feller. I would love to meet him.
Engine
Kentucky
It's absolutely mind-boggling how much metalworking equipment and tools he has there. It would be great to be able to learn the craft from someone like him.
Tommy J.
Florida
Thanks! Tubalcain is my newest best friend I've never met. Fun to watch him lead us through his lair. New Guy Tommy J. here, intro elsewhere.
Jrad
If you guys are interested in seeing an absolutely killer shop tour the machinery in this video is incredible.
K
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I've watched his videos also, and to answer your question.....Yes, he is setting a good example for you. But remember, you only get out of it what you absorb into the gray matter. Toms Techniques, Tubalcain, and a lot of the others that you run across, can all be good as long as you pay attention, and learn to distinguish the bunk from the mix. I have watched a few videos put up that can get a person into trouble safety wise. Learn your safety basics first, learn your machines second, learn your materials third, and learn your machining fourth. Once you have the first three down, the fourth will come a lot easier. Safety and machines is pretty much a given, but why materials? Materials all machine differently. You need to learn what materials do what and why, and you can't do that without #1 and #2....safety and machines. Aluminum machines way easier than steel, but can grab and get you into trouble. Some material can heat up quicker than others and swell SHUT instead of the old adage of heat expands, cold contracts. You can drill and ream aluminum and get a perfect size hole depending on your speed, feed, and lubricants. Use the same on a piece of titanium and snap a drill or reamer because it swelled shut on your tool.
Like I tell everyone when it comes to machining....become one with the material, become one with your machine. Both will talk to you and tell you whether things are good or whether they are bad. Learn to listen to both.
But yes.....Tom's Techniques will teach you what you need to know as far as BASICS. Tubalcain's videos will do the same. You need to learn the basics, then let you machine talk to you. No lesson online will teach you 100% what you need to do, and no person will teach you 100% what to do, but they will teach you the basics that you need to know. After you learn the basics, then you go out on your own and hone your learned skills. You will find that certain things can be done faster one way that another way, but what you ultimately want to strive for is perfection or as close to it as you can get.
And to add to things when it comes to machining....learn what you can, and above all, have fun. Machining is an art. It is taking a block of raw material and cutting away what you don't need to bring forth a usable object. And just like two artist, both may arrive at the same looking sculpture, but the way they arrived there was totally different. Enjoy what you do. :thumbup:
bczygan
I find it just magical that you can shove one piece of metal against another and remove pieces of the second one. That you can abrade metal with rock for a smooth finish. That you can ream and achieve a press fit that is tight enough that air won't escape without pushing hard on it. It's amazing what a mill can do and a lathe is mesmerizing. Drilling a hole, and tapping it, in a piece of steel is just fun, and making a series of them, spaced accurately is so satisfying. And that isn't even talking about annealing so you can bend or heat treating aluminum or welding or all the other fun stuff.
Bill
Gasgt1
100 miles SW of Chicago
Tubalcain was my shop teacher.
Great guy that I still see every now and again.
I ran into him a few days ago and talked for a while.
Mr Pete is a cool guy:thumbup:
Lassen Forge
Tubalcain... Mr. Pete... has never ceased to amaze me... from his videos to now, seeing his shop in a 15x15 area... THAT'S Inspirational!
I never realized it until now, but he even LOOKS like an old school shop teacher (tho somehow I suspect he still has 10 fingers...).
:bowdown: I really MISS teachers like that. Thank you for sharing!
Hephaestus29
Indianapolis
He said in one of his videos, that he didn't
use his Hardinge Speed Lathe much. I
asked him if he would sell it but he said
he wasn't ready to sell it.
