Least used Snap On Tool.....
purpurite
Aurora, Illinois
B1356E brake spring retainer tool. Got it with a Formula Vee that I bought a few years ago. Never did brakes on the car, sold the car and still have the tool in my tool chest. Will probably never get used again in my lifetime.
bigenos
If you ever have to service a trailer with electric drum brakes you'll probably need it so hang on to it.
yogitech
Orlando, FL
I've used my SO B1356E more times than I can count. There's still a lot of drum brakes on the road.
As far as nevertheless used SO, I would have to say my ratcheting adapters....
Heavy Metal Doctor
Mason Dixon Line
Its a toss up between the Detroit Diesel 71 series injector / rack tools set and the Chrysler ball joint Socket for the screw in type on 70's pickups ( may cover more, but never had any newer one)....neither one has been used in 10 years at least....
supersteve
Camas, WA
I'd have to say the 3/8 drive chrome 18mm half-deep universal socket I got for old Ford Taurus front motor mounts, Borrowed these several times long ago, bought one for myself and never used it since.
shockwave
Marietta,ga
Probly my 11/16 snap on spark plug socket for m-series BMW motors used once now it just sits and gathers dust
ClrkLndeKmt'su
Dayton, TN
this
My Subaru head bolt socket. My friends and I have around 8 Subaru's between us, I have literally used it one time in the last year. Without it though, the engine has to be removed to access and torque the bolts properly.
CoryZ
WI
My small snap-on collection consists mostly of wrenches--all bought used. I decided to treat myself to good wrenches after getting frustrated with the junk I had. I don't wrench for a living, so aside from helping family members do things I don't see the huge variety of cars, trucks, equipment, etc. that some of you do.
Some of the standard set combo haven't been used yet. I don't think I'm touched more than a few of the flare wrenches on the metric side of things and none of the standard ones yet. They're there if I need them though.
chickenhauler
Pennsylvania
this
I have that socket too - have yet to do a Subie head gasket job. My Atech is 3/8 drive, so I'm trying to figure out if it will even be a help lol.
ClrkLndeKmt'su
Dayton, TN
have you got a part number or picture of this socket please?
Click the link lol. But it's part number S6214. Places the head of the torque wrench above the spark plug tunnels/rocker arms, but not so far that it hits the rear unibody, which is impossible to get with a deep socket.
ClrkLndeKmt'su
Dayton, TN
The torque procedure is STOOPID haha. The SO Techangle is a must because of multiple 90 degree and 180 degree turns both clockwise and counterclockwise. My first one I literally suffered thru, because of not having the Techangle. If I do another I'm dropping the money for the wrench and saving the headache
ClrkLndeKmt'su
Dayton, TN
So in other words, I'll be buying a 1/2" techangle.
Unless you are damn good at guessing angles, or remove the engine and install ARP studs, only about and additional 1.75 hours of work, but takes away the excuse to buy a badass tool. Here is the sequence stolen from google, without the picture.
1) Tighten all bolts to 29 N-m (3.0 kgf-m, 22 ft-lbs) in alphabetical sequence.
2) Then tighten all bolts to 69 N.m (7.0 kgf-m, 51 ft-lbs) in alphabetical sequence.
3) Back off all bolts by 180" first; back them off by 180" again.
4) Tighten the bolts (a) and (b) to 34 N-m (3.5kgf-m, 25 ft-lb).
5) Tighten the bolts (c), (d), (e) and (f) to 15 N.m (1.5 kgf-m, 11 ft-lb).
6) Tighten all bolts by 80 to 90" in alphabetical sequence.
CAUTION: Do not tighten the bolts more than 90".
7) Further tighten all bolts by 80 to 90" in alphabetical sequence.
CAUTION: Ensure the total "re-tightening angle" [in the former two steps], do not exceed 180".
sberry
Brethren, Michigan
other than that, probably any of my torque wrenches
Its certainly something I dont use a lot.
tubing bender.
This falls in there somewhere especially applying to general brake service on 10 yr old fleet stuff. We can be custom if we need to be but I rarely buy line by the roll anymore, stock some pieces of various length and a few couplings, come close enough.
A lot of these fall in to tools you got to have but don't use, I am sure this not only relates to snapon but in general. A crowsfoot is a poster child for that, bet most of them in the world never get used? Great product to sell and warranty huh? 85% of the set sits in a box which cost money,,, hahaha
ationgco
Blue point ya8890 I think.
10mm valve lash adjuster. Bought it with a bunch of other tools, never used it.
If you still have this tool and you are open to parting ways with this tool, I can give it a new home and will definitely be of good use. 😊 PayPal funds ok?
2ndGearRubber
Pittsburgh
I bought the full set of connector depinning tools, but I mostly disassemble them all with one single tool from the kit and a pocket screwdriver. Oh well, I've warrantied the few I use enough times to end up ahead.
2ndGearRubber
Pittsburgh
I had a hunch they would discontinue the ignition coil flag-pickup, so I bought one. Well I was wrong. Have yet to use it as i have a paddle probe and a set of 4 pico branded secondary leads. I bought S6560 after a run of rear wheel bearing jobs, have not had one since.
garfieldzzz
BY
24“ braker bar, keep on using the 24“ ratchet instead. 3/8 in 1/4 body ratchet is also seldom used.
Honch
Danville, IN
Twenty plus years ago I worked the flight line, we weren't allowed cordless tools, so speed handles were king. I haven't used this in years.
Also, this 1/8" wrench that was awesome for getting to lock nuts on cannon plug mounting hardware. I don't even remember the last time I used it.
Cc_windsurfer
SB, ca
1/2" drive deep socket set. Was gifted to me by one of the partners in our race shop, but in 20+ years i think i have only used the 5/8 and 9/16. Guess I am a 3/8 and 1/4" drive guy.
Snapped-off
Indiana
Toss up between the brake service set and the NOS old style hard handle nut drivers that I don't have a picture of.
They both live in the overflow box.
