Leave it or move it.
Move it or leave it
  • Pay $2600 and move it
    Votes: 72 73.5%
  • Save $2600 for future bumper repairs and leave it
    Votes: 26 26.5%
  • Total voters
    98
polexican23
burbs-Illinois
Figured a poll would help make my decision.
Right now I am in the beginning of a detached 24x30 garage build. By driveway is kind of narrow at 10ft at its widest point. Towards the end of the drive there is a gas meter for the home. It shrinks the drive to about 8.5 feet.
Nicor (local gas supplier) has quoted a sum of $2600 to move the meter to the opposite side of the home. Doesn't include new piping into the home. Just the meter and new gas line.
P
polexican23
burbs-Illinois
Only pic i have of the meter location
mmb617
PA
I don't know what to advise. That's a lot of coin to move the meter, but on the other hand it's only a matter of time till it gets hit which will probably be even more expensive.
You might get used to avoiding it, but somebody else will tag it for sure.
czervika
Depends. If I needed to get a trailer back there on a regular basis, yes. If I'm just driving typical cars or trucks back there, I'd leave it.
dave89iroc
outside Detroit, Michigan USA
whats around that corner?
before anything, put some soapy water in a spray bottle, clear the dirt away where the pipe enters the ground, and spray the pipe around where it was at the surface, look for bubbles, if its leaking, gas company will likely send a crew out to replace the pipe, talk to the crew, see if they can move it around the corner
dave89iroc
gas company here(DTE) sent crews out inspecting all lines, mine was leaking, they replaced the line, replaced meter, relocated the meter to outside, and re-lit my pilot lights, no charge
bimmer1980
York, PA
Is it something that has to be done prior to something else? i.e. driveway?
Or can you easily put it off and have it done later?
I would sink in some posts on either side of the gas meter and roll with it....
However, as others have said, if you are bringing in trailers, it would be helpful to have it gone.
However, I would definitely be setting aside money to be able to move it at some point...
P
polexican23
burbs-Illinois
Fence is the neighbors. yes as far as it is going to go
Around the corner is the electrical in and a water spigot. Nicor already said no to moving it around the corner.
It isn't currently leaking, NICORs idea was a new brace to stead it.
I would most like install a cement ballard (<--sp?) to protect future hits if I don't move it.
No trailers now or in the future.
JohnK007
Downers Grove, IL
I think I'd move it and just roll the cost into the overall garage project. The thing that makes me lean that way is the fact that the gas line to the meter is running under your drive so if there's ever a leak or problem with the supply line, they'll have to dig up your new driveway to get to it. The likelihood of that happening is slim but you never know, and like was said it's only a matter of time before someone kisses it. It will also be in the way for snow removal which is going to further restrict the width of the drive. I admit $2600 is a bit stiff but cry once and be done with it.
Ray916MN
Orono, MN
If it isn't moved it needs to be protected from being struck. Subtract the cost of concreted posts to protect the meter. This will be the true cost of moving the meter.
jives
Central NY
Why move it to the other side of the house? Why not around the corner? It would seem you could tie it into the existing house piping much easier and would require less piping underground.
ChaseDE
Delaware
same question.
if it bothers you enough to make a topic here, you should move it because it will always be there sneering at you if you don't.
if you don't move it, like others said, put some bollards around it.
LB-1911
Northwestern Il.
Because Nicor said no.
rlitman
Long Island
How often do you expect to be driving past it? Dividing up the cost of moving it over rarely needing the space, vs using it every day can make a big difference in your decision. Will you be parking in that detached garage regularly? What sort of vehicles will you be driving past it?
Bollards are needed for sure. I'd put hard bollards up to just over the height of the meter, but don't go too high, or you'll knock your mirrors off. Above them, I'd put a reflective fiberglass stick or something flexible and visible, because low bollards can be hard to see, especially in your mirrors.
Check with the local building authority and see if there are any regulations about how close it can be to a window or door. Neighbors got theirs moved for free because it was too close to a window,
sierradmax
Rhode Island
With the gas company there, how about adding a 2nd meter or line to the garage for future heating. Just a thought.
DaveIRL
get if shifted the pole is wrong heres why if you caused 2600 dollars damage to a vechicle the gas line would also be affected making the cost potentially 2600+ 2600=5200
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I would bite the bullet and have it moved, and then at the same time, have a gas line ran to the garage for your heater or furnace.
Richard Cranium
central Washington
I would move it also, You could real easy do more damage then that to your car or truck. Plus you still have to move it. plus with my luck it would be a weekend or holiday and you will pay time and a half for labor. And prices will only go up. That is todays prices. Bite the bullet and be happy.
txvwnut
Bedford, Texas
Move it. My brother has the same drive setup as the op and ran into his late one night with his trailer. Breaking your gas meter is not something you wanna do, especially after midnight.
-Brent-
Utah
I would lean toward moving it but what's the job like inside with getting it all hooked up with it entering the other side of the building?
tthornto
I would keep pushing to have it moved just around the corner. If they won't move it around the corner in the back can it be moved around the corner in front of the house? Even if they charge the same amount to move it around the corner as they do to move it to the other side of the house it is worth it to keep your yard/landscaping on the other side of the house from being trenched up, unless you want an excuse to redo the landscaping then have them put it wherever is cheapest easiest or most aesthetically pleasing.
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
I have to agree with this but the cost you need to look into as that does sound a lot. If you leave it and it gets hit what will it cost you then ?
Larryjones
WV
My gas company would allow me to move it myself. I would go to the street and start trenching across the yard and head around to the other corner, avoid the drive way. Use the yellow line. They would provide the pipe for the street hookup and the riser and meter.
amkluttz
Concord, NC
Around the corner
I would call them back and ask them again about moving it around the corner. I would want to know why they say it can't be moved around the corner. There is typically a rule about it not being within a certain distance (I believe 10' in my area) of an ignition source which the meter could be. There shouldn't be any rules about being close to a water line. Sometimes you just get ahold of someone who doesn't know or isn't interested in doing the work. Make them explain why. The worst that can happen is they say no again and you've wasted a little time. It would make the most sense for piping back in to existing house lines.
-Andy
bigdav160
Deep in the heart of Texas
I moved my meter myself. I had to replumb the piping inside.
The POCO charged me $500 to run the plastic pipe from the meter to the main. They thanked me for digging down the main where their connection was to be made. LOL
wssix99
Chicago, IL
At the point you need to pay that much money to move the meter, I'd look at getting the gas company out of your life entirely.
So, I would not move it.
I would:
- Move the meter in closer to the house. That will give you an important 6".
- Not worry about the rest. As you drive by, you'll need some buffer from the house and fence for your side mirrors. Once the meter is up against the house, it will just pass under your side mirror space as you drive by - no problem. You also have the downspout there, so keeping away from that will also give you plenty of clearance from the meter.
jwh
Rochester NY
Move that meter! As has already been said, potential for disaster exists.
Here's a YouTube audio from earlier this year. Gas meter was inside the garage. Was broken off by car hitting it.
Henrietta is a town outside Rochester NY
John
