Lectrolite, Lectrolite Tru Fit
genog
Silicon Valley
I went to see my favorite Flipper yesterday.
Flipper E. McBay :ROFLMAO:
No tools this time around except for this ole Lectrolite DBE
I've seen it in his den for months on end....
....he also has a Tru-fit DBE which I will get next week unless he vulturizes some tools somewhere
Imma sucker for DBE wrenches
S-K Tool Fanatic!
NE Ohio
Got all these wrenches and a pair of pliers at a flea market. The pliers were $2, all the wrenches were 75¢ apiece.
This Lectrolite wrench is odd, one side it says Lectrolite, on the other it says S-K.
I think on any S-K Lectrolite combo 9/16” or smaller there wasn’t room for the whole S-K Lectrolite marking on one side so they split it up side to side.
Steven 33
Here is what I believe to be a complete DOE set. The wrenches and holder were scattered around the garage at yesterday’s estate sale.IMG_0697.jpegIMG_0698.jpegIMG_0699.jpeg
I wonder if there was a different set that goes up to 1" or maybe higher? Can't remember if I've seen bigger than 15/16 x1" with 7/8 × 13/16 under that. Were these one made before the ones marked with the trufit name I assume?
They were selling very similar Dunlap marked wrenches to Sears until 1960. I didn’t mean to imply that the wrenches in the set were the only sizes they made. They were just the sizes that fit into that particular holder.
-DonIMG_9667.pngIMG_0305.jpegIMG_8544.jpegIMG_5775.jpegIMG_5776.jpegIMG_5777.jpegIMG_5778.jpegIMG_5779.jpegIMG_5780.jpeg
I initially thought that these wrenches that I found yesterday might be a Vlchek Auto kit set but after they came out of the evaporust I realized that with the position of the size markings that they were much more likely to be unmarked Lectrolite. IMG_1972.jpegIMG_1973.jpeg
humber2
Downunder
Lectrolite Ford Brakes #6000
I suspect these are early 1930’s production as most were kinked from the V8 era onwards.
The interesting error on the darker one is the dimensions given as 1/2 and 9/16 but the broachings are 7/16 and 1/2
Provincial
Near Salem, OR
I suspect that the same forging was used for more than one type of wrench. Perhaps a hex wrench, which would have had thinner walls and allowed larger 12-point openings than the 8-point brake wrenches. A blank got in the wrong pile during processing.
leg17
Kentucky
I dunno. The "FORD BRAKES" and "6000" appear to be forged into the blank from the die.
leg17
Kentucky
On the one side. You are assuming that the lettering on both sides were forged at the same time
Generally the hot blank is positioned between the top die and the bottom die and squeezed together, or 'forged'. Both sides at once. I'm not familiar with a 'one-side-at-a-time' forging process.
Provincial
Near Salem, OR
Unless the upper and lower dies are somehow linked together, it is possible that an upper die could be used with the wrong lower die, when the blank is used for more than one tool.
leg17
Kentucky
Humber has it right.
It was broached differently than the wrench blank markings for whatever reason, intentionally or accidentally.
I am straining my brain to rationalize a good reason for intentionally marking any wrench one step up from its actual broached opening and can't come up with anything. As we all know, everyone and their brother were making these wrenches for years and they were all made and advertised as 7/16" x 1/2", except for Snap-on, which indicated, oddly, that they were 15/32" x 1/2" in their 1932 catalog.
Speaking of their abundance..., Jock started a thread just for 'Ford Brake Wrenches,' and there is another example of the Lectrolite oddball, posted on his thread here. Implying that it was more than a simple, short-lived "mistake."
leg17
Kentucky
That one appears that the broaching matches the sizes marked.
Looks the one here was mixed in the wrong batch and got broached the more common 7/16-1/2.
Two things. Firstly, how are you arriving at this conclusion from afar? @Ed in Virginia did not report a measurement of the broaching. (Perhaps he will help us out now that I tagged him.) Secondly, the premise of his wrench having the correct markings and the correct broached openings is that there are 1/2" x 9/16" Ford Brakes wrenches. Are there?
I was with you on the single forging, both sides at the same time, but now you lost me. Sorry. Probably flawed critical thinking on my part or something I am missing. How would a "Ford Brakes 6000" wrench, with one side of a die bearing that name and part number, the other side of the same die bearing the branding and size markings, broached with the correct size openings, get "mixed in the wrong batch"? Since it was forged first, then broached, then finished, a forging process mishap would seem to disagree with your earlier position (again, that I happen to agree with), no? If it didn't have the "Ford Brakes 6000" on the other side, then I could see how it might could've been intended to be a 1/2" x 9/16" DBE with double square openings, mixed up in the wrong batch, and broached 7/16" x 1/2" instead. As is, it seems like a die making issue, no?
Provincial
Near Salem, OR
Two things. Firstly, how are you arriving at this conclusion from afar? @MisterEd did not report a measurement of the broaching. (Perhaps he will help us out now that I tagged him.) Secondly, the premise of his wrench having the correct markings and the correct broached openings is that there are 1/2" x 9/16" Ford Brakes wrenches. Are there?
As I pointed out in post #146, forging dies are not one piece, but consist of two dies. One is attached to the moving part of the forging press, and the other to the fixed part of the press (base). I believe they are kept together as sets, but are not physically attached to each other. Thus, it is possible for dies to get mixed up, as long as they match up well enough to form the part. If the part is completed by broaching, it could be possible that the blank was broached mismatched to the forged-in identification. Or that the die identifying the opening sizes was mismatched with the one using the part number.
For the 9/16" identification, I see two possibilities. One is that there is indeed a 9/16" opening, and the other is that the diemaker misread the size he was supposed to show. Such a mistake should have been caught quickly in the quality control process, but a "bean counter" may have decided to send the mistake out as a cost-saving decision.
I'm only familiar with uniform dies, Jock, but I believe you. That's irrelevant to my overall point, though. Whether a single two-piece die was made wrong, or one half of two dies was mistakenly used, I do believe it's a die mistake. A less convoluted way to express my opinion on this than I have above would be to simply say that intent matters. The question with respect to humber's oddball wrench (marked 1/2 x 9/16, but broached 7/16 x 1/2) is, is it marked wrong? Or broached wrong? I think it's marked wrong. I looked through dozens of catalogs in the 30's and into the mid 40s and I can't find any mfgr offering a Ford Brakes wrench with 1/2 x 9/16 openings. as always, I could be wrong. Just laying out my thought process.
I generally don't pick up Lectrolite tools, but these battery pliers seem longer than most, and they have an unusual stop on the handle. I think the only other pair of pliers I have with a stop are sapper/cap crimpers.
I went through my random Craftsman spares recently and gathered up all of my Circle G chisels and punches. Circle G Craftsman tools have long been attributed to Lectrolite Corp. but I can’t really find any concrete evidence why. I’m hoping that one of the Craftsman experts happens by and does a deep dive into who really made these chisels and punches since there isn’t a single Lectrolite chisel or punch shown in this entire thread. IMG_4360.jpeg
Here is a set posted in 2019 in the Garage Sale thread.IMG_1220.jpegIMG_1222.jpeg
edit#### eBay photos spotted today. Made through the Crown era. IMG_1224.jpegIMG_1225.jpegIMG_1226.jpeg
Ricky Joe
Roanoke, Va.
There was never a 9/16” square brake adjustment for the Ford Models T, TT, A, AA, B, or BB. If there was a Ford made bigger than those, I am unaware of it. Sizes should be 7/16”, 1/2”, or possibly 15/32”.
ninosca9
Any idea on the age of these? I just found some in a bin.
